90-93 integra rear discs fit on an EG? Some say yes and some no
I really need to know if the rear discs of a DA will fit on an EG? I see some people say they fit and others say they dont. If the trailing arms dont fit what about taking torx bolts out and not swapping the whole assembly, would that work? Anything you know for sure would be a great help
The trailing arms will definently work. The only difference is the size of the trailing arm bushing (which has no impact on geometry). The DA's trailing arm bushing is slightly larger and that means different part numbers from civics & other integras. I don't know if the LCAs will work on the civic, but the rest works fine.
Don't forget the proportioning valve from the teg (40/40).
And don't believe people when they tell you that you will need a brake booster & master cylinder with a rear disc swap. If your pedal is mushy after the swap, then it is because you have not bleed all the air out of the brake system (I know from experience)...
ok thanks so I can swap out the bushings for civic ones? then i should be ok? thanks for the help guys
No no no, the bushings will work fine. It's just that once it comes time to replace them, you have to make sure to get the correct ones for the Integra trailing arms.
As for the e-brake cables, I couldn't tell you if they will fit or not. In the worst case, they won't work. Then all you would need to do is order some new ones for a rear disc model civic of the same chassis (IE: Si Hatchback, ABS 2 door or ABS 4 door). For discount OEM parts, I perfer SLHondaParts.com or HondaAutomotiveParts.com...
hefftone79
Jun 28, 2009 07:15 AM
drew2
13
Jul 27, 2006 07:50 AM
Mistermark
May 16, 2006 12:46 PM
-DC2-
Jan 17, 2003 10:48 AM
