yellow foglight question
Old Dec 1, 2005 | 11:37 AM
G2DAB18's Avatar
Default yellow foglight question
I have some JDM one pieces for the DA and I have already taken the glare guards out of the foglights. I wanted to keep my fogs yellow and was wondering which foglight setup would be brighter?? I'm either going to use a super white H3 bulb and the stock yellow lense cover or ditch the yellow lense cover and just get some nice yellow H3 bulbs. Which way do you guys think would be the brightest??
I'm kinda thinking the yellow bulb would be brighter than the white one with the yellow lense cover because it wouldnt have anything covering the bulb. But would a super white bulb make up for the difference?? I still have my one pieces apart, what would you guys do??
Old Dec 1, 2005 | 05:43 PM
G2DAB18's Avatar
bump
Old Dec 1, 2005 | 08:25 PM
G2DAB18's Avatar
Its easy as hell dude. Just bake them in a oven at like 185 degrees for like 10-15 minutes and they basically pull apart. You need to remove the clips around the light and there is one small little screw on the corner light that needs to be removed also. Other than that just heat up and pull apart. You'll wanna silicone them up real good when your done so you make sure no moisture can get in.
As for my question, anybody??
Old Dec 2, 2005 | 05:53 PM
G2DAB18's Avatar
up
75thRanger
Dec 11, 2006 06:42 PM
G2 Speed
25
Sep 29, 2006 04:00 AM
Dongoesby
Dec 1, 2005 04:18 AM
DB8_TEG
Aug 7, 2003 08:51 PM
Jaisun
Nov 12, 2002 07:53 PM
