I'm going to change my radiator, have some Qs
Old Dec 1, 2005 | 07:28 AM
Nocturnal's Avatar
Default I'm going to change my radiator, have some Qs
What is the best way to remove the bottom hose from my radiator/engine?
I have a EG h/b w/stock d16 engine. I'm just going to get a like-oem radiator replacement. Thank you.
Old Dec 1, 2005 | 07:43 AM
JimmyAtlantis's Avatar
Default Re: I'm going to change my radiator, have some Qs (Noct)
Loosen the clamp and pull it off. If it's stuck use a "box cutter" and slit the hose (length-wise) from the end of the hose to the end of the neck it's connected to.
Old Dec 1, 2005 | 08:29 AM
littleredcivic's Avatar
the easiest way is different depending on the car. if you have a short ram intake or stock, then remove it and remove the hose from the neck and pull it out with the radiator. if your car has a cold air or does not have the lower splash sheild, then remove from the lower radiator neck. radiator hoses (upper and lower) should be replaced when replacing a radiator. they are less than 30 from the dealer.
Old Dec 1, 2005 | 10:45 AM
Nocturnal's Avatar
How do you reinstall the hose though? Is there enough room to just reach down there and connect the clip that holds it onto the radiator/block?
Old Dec 1, 2005 | 11:30 AM
dohcdelsol's Avatar
Default Re: (Noct)
just push it back on... change the clamp
common sence
Old Dec 1, 2005 | 11:43 AM
Nocturnal's Avatar
Should I reach from the top or the bottom? If I remove the bottom I'll have to remove the splash guard.
Old Dec 1, 2005 | 11:45 AM
Default Re: (Noct)
This isn't a complex task. You have plenty of room to go at it from the top. You should be able to tell just by looking.
Old Dec 1, 2005 | 11:51 AM
Stoich EG2's Avatar
Default Re: (JimmyAtlantis)
hahahaha, isn't it self explanatory when you look at the darn thing?
Old Dec 1, 2005 | 11:58 AM
Hybrid96EK's Avatar
Default Re: (Noct)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Noct &raquo;</TD></TR><TR><TD CLASS="quote">Should I reach from the top or the bottom? If I remove the bottom I'll have to remove the splash guard.</TD></TR></TABLE>
Jesus dude. Its just a car. Go out there, remove the hose, put it back on. Your not going to **** it off or something if you don't touch it just right....
TEGGRY
Jun 13, 2006 10:27 PM
BrokenRex
Oct 27, 2005 12:03 PM
WRTEG
Apr 3, 2004 04:59 AM
sloweh3
Feb 17, 2004 04:32 PM
wdskuk
12
Jan 24, 2004 09:38 AM
