difference between jdm d16z6 vtec and jdm d15b vtec
Old Dec 1, 2005 | 06:46 AM
f150harleytruck7's Avatar
Default difference between jdm d16z6 vtec and jdm d15b vtec
which one should i get im just replacing the worn out d16z6 in my 95 civic ex, planning on a turbo too, but the jdm d15 is much cheaper, up to 300-400 cheaper, they say everything bolts right up and works with my computer, just want the better of the two motors, and what a good place to buy a jdm motor? thanks
Old Dec 1, 2005 | 06:48 AM
. L i z's Avatar
Default Re: difference between jdm d16z6 vtec and jdm d15b vtec (f150harleytruck7)
hmotorsonline.com
Old Dec 1, 2005 | 06:51 AM
Kendall's Avatar
They have similar peak power, but the Z6 has more torque. I believe the B has a slightly more agressive profile. I'm not sure how they would dyno back to back using a stock P28 ECU though.
litterbox's Avatar
I am a (Trial User) Army
Default Re: difference between jdm d16z6 vtec and jdm d15b vtec (lilhondagirl)
You can get a full z6 swap for like 400 on HT classifieds as well man.
Old Dec 1, 2005 | 07:47 AM
ELSpool's Avatar
I was in the same situation, bought a 95 civic Si that was previously boosted, so I popped in a JDM D15B for DD usage, with I/H/E and a chipped ECU (sold the turbo setup as I have another boosted honda). It hauls ***, great little motor!
Old Dec 1, 2005 | 07:51 AM
Default Re: (ELSpool)
you think the d15 would be just as good, or u think the d16z6 would a little better?
Old Dec 1, 2005 | 07:55 AM
ELSpool's Avatar
Default Re: (f150harleytruck7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by f150harleytruck7 &raquo;</TD></TR><TR><TD CLASS="quote">you think the d15 would be just as good, or u think the d16z6 would a little better?</TD></TR></TABLE>
Personally, I feel the D15B is noticebly faster in vtec over the Z6, and under I can't tell the difference between the two. I did the swap because living close to Toronto and Montreal, there are boat loads of JDM engine importers. So it was much easier/cheaper to get a clean JDM motor, than it was is to replace the Z6 with something of similar mileage/condition as a JDM motor.
Old Dec 1, 2005 | 09:40 AM
i talked to places that said they had z6's that were jdm, i thought the d15b was the jdm for the z6, do you know?
Bisimoto
Mar 18, 2009 11:14 PM
Bisimoto
Mar 18, 2009 07:31 PM
95 honda8
42
Apr 10, 2008 08:25 AM
jdmallstar2000
Oct 16, 2005 11:17 AM
speedycivic91
Sep 14, 2004 10:46 AM
