tranny grind
Old Dec 1, 2005 | 05:38 AM
twenty's Avatar
Default tranny grind
if the tranny is griding into 2nd and pops out of gear when i try to put it in, whats the cause of that? syncro's?
Old Dec 1, 2005 | 06:00 AM
crxnj's Avatar
Default Re: tranny grind (.bump!)
Maybe low on fluid,,Change it and put 2qt of honda motf and see what happens..
Or maybe some shiftlinkage problems?
Or maybe 2nd gear is just gone,,
Old Dec 1, 2005 | 09:01 AM
jdmcars.com's Avatar
Default Re: tranny grind (Mr.speaker)
Probably internal. Is it something that just got worse overtime?
Probably a bad syncro and maybe a bad/bent shift fork.
Old Dec 1, 2005 | 10:50 AM
twenty's Avatar
Default Re: tranny grind (jdmcars.com)
could it possibly be all fixed by just changing the fluid to a syncomesh or would it be a waste of time?
Old Dec 1, 2005 | 11:55 AM
Pee Wee's Avatar
depends what tranny your running. if its a d series tranny then i would just get a "new" one. d series trannies can be had for pretty cheap. i sold one for a bill.
Old Dec 1, 2005 | 12:14 PM
twenty's Avatar
Default Re: tranny grind (EF8opey)
yeah its a d series. some guy is selling a 96cx will it bolt up to my 00dx motor?
Old Dec 1, 2005 | 07:39 PM
crxnj's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .bump! &raquo;</TD></TR><TR><TD CLASS="quote">
yeah its a d series. some guy is selling a 96cx will it bolt up to my 00dx motor? </TD></TR></TABLE>
Yeah it will bolt up but that's a hyrdo tranny..Its a pain to convert to hydro and not worth it with d-series trannys,,especially a cx tranny....
Try to find a 88-91 dx,si tranny..
Old Dec 2, 2005 | 03:41 AM
StorminMatt's Avatar
It sounds to me like the synchro for that particular gear has been bad for some time. When this happens, the repeated grinding of the gear tends to wear out the slider and the external spline on the gear it mates with. This causes the transmission to pop out of that particular gear. It sounds like time to either replace the gear/synchro/slider or the transmission.
94DCTeg
Aug 8, 2011 12:20 PM
Civic889
May 15, 2007 07:02 PM
silverboost
Apr 13, 2007 10:06 AM
projectTeG
Aug 5, 2006 09:05 AM
buck02
Mar 5, 2006 07:34 PM
