Parts needed for Timing belt + water pump change
Old Dec 1, 2005 | 03:00 AM
Integra Integra's Avatar
Default Parts needed for Timing belt + water pump change
I know I need the Timing belt, water pump and what else do I need? Were is the best place to order this?
Thanks!
Old Dec 1, 2005 | 05:19 AM
Racermech's Avatar
Default Re: Parts needed for Timing belt + water pump change (Integra Integra)
the 3 accessory belts, you can swap the tensioner pulley. If you want OEM you can contact user "Len" or go to http://www.acuraparts247.com
tegmaniac's Avatar
I would recommend getting a valve cover gasket w/spark plug hole gaskets, hondabond, and all new accessory belts. I would only get oem parts at the dealership when it comes to everything except the accessory belts.
Old Dec 1, 2005 | 09:16 AM
nsxtasy's Avatar
H-T Order of Merit
Default Re: Parts needed for Timing belt + water pump change (tegmaniac)
Dealers who have good prices on parts are listed in this topic.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tegmaniac &raquo;</TD></TR><TR><TD CLASS="quote">I would only get oem parts at the dealership when it comes to everything except the accessory belts.</TD></TR></TABLE>
If that is a comment directed to the recommendation of h-t user "len", please note that he works at an Acura dealership (Baranco Acura) so if you buy from him, you are buying new parts from a dealership, same way as you would from Delray Acura or Sunnyside Acura or your local Acura dealer.
Old Dec 1, 2005 | 10:16 AM
M Coop's Avatar
Don't forget the cam seals while you're in there
Old Dec 1, 2005 | 06:27 PM
Default Re: Parts needed for Timing belt + water pump change (M Coop)
What are the accseory belts that I need exactly?
Thanks
Old Dec 1, 2005 | 06:34 PM
# Air Conditioning belt 38920-P75-A01
# Power Steering belt 56992-P72-003
# Alternator Belt 31110-P75-014
Are those the asscesory belts?
Old Dec 2, 2005 | 08:53 PM
Just ordered all my parts from Sunnyside Acura
12513-P72-003 SEAL, R. CYL HD
14510-P30-003 TENSIONER 1
12342-PG6-000 GASKET B, HEAD COVER
12341-PR4-A00 GASKET, HEAD COVER
56992-P72-004 BELT, P.S. PUMP
31110-P75-014 BELT, ALTERNATOR
38920-P75-A01 BELT, COMPRESSOR
14400-P7J-004 BELT (125RU26)
19200-P75-003 WATER PUMP
14516-PR4-A00 SPRING
Total was $285 and I figured out my coolant leak was from my water pump I never saw antifreeze but now see were its coming from.
I will also be doing a valve adjustment, cam seal replacement, transmission flush and tune up when I do this. Thanks for all your help!
Old Dec 2, 2005 | 08:57 PM
00IntegrAllmotoR's Avatar
HT Black OPs
sounds good!
Old Dec 2, 2005 | 09:03 PM
Default Re: Parts needed for Timing belt + water pump change (00IntegrAllmotoR)
Thanks!
Little-Acorn
Sep 3, 2014 04:54 PM
Freshazzburu
Mar 1, 2007 07:37 AM
cbmprelude
Sep 2, 2005 07:39 PM
schumi
Jun 10, 2005 08:56 AM
FatAndFurious
Jan 13, 2005 10:52 PM
