JL W7 or JL W6v2?
Old Dec 1, 2005 | 12:08 AM
SD1222's Avatar
Default JL W7 or JL W6v2?
I was wondering which of these 2 subs would be louder? 2 12' JL W6v2 or 2 10' W7? Right now i have 2 12' W6v2 and i just found a good deal on 2 10' W7. Should i keep the W6v2 or get the W7 instead? Any help would be greatly appreciated.
Old Dec 1, 2005 | 12:25 AM
XaznKewLguyX's Avatar
Default Re: JL W7 or JL W6v2? (jdm_spoonEG)
i think the w7's because i have a w7 and i tried my friends w6 out and my w7 was way louder
Old Dec 1, 2005 | 12:55 AM
SD1222's Avatar
Default Re: JL W7 or JL W6v2? (XaznkewlguyX)
did your friend have the new design w6? or the old skool one?
Old Dec 1, 2005 | 08:16 AM
fcm's Avatar
fcm
Old Fart
Assuming both are 10" drivers and they are installed in proper boxes and properly powered, the W7 should be louder by a tiny bit.
10W6V2-D4- 400W (Pt) thermal power handling, DVC 4ohm. so 800W for 2
10W7-3 - 500W (Pt) thermal power handling, SVC 3ohm. so 1000W for 2
As you need twice the wattage to get a 3dB gain in output, [what we as humans need to tell if it's louder] I doubt you can tell the difference between the two sets of subs.
I would be willing to bet I can make a bigger difference with the 10W6V2-D4s that you already have, just by installing them properly in a better built box, mounting the box properly, wiring and powering them properly, [assuming that has not already been done] 94
Old Dec 1, 2005 | 10:07 AM
Default Re: JL W7 or JL W6v2? (fcm)
yup 12" JL w6v2 and a box built to JL specs and i have a w7 with the prowedge box
Old Dec 1, 2005 | 11:31 AM
GSteg's Avatar
2 12W6v2 will be louder than 2 10w7
Old Dec 1, 2005 | 12:06 PM
SD1222's Avatar
Default Re: (GSteg)
cool i'll stick with my 2 12' w6v2 then, thanks for the input
Old Dec 1, 2005 | 12:39 PM
Skip01's Avatar
Default Re: (jdm_spoonEG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm_spoonEG &raquo;</TD></TR><TR><TD CLASS="quote">cool i'll stick with my 2 12' w6v2 then, thanks for the input </TD></TR></TABLE>
Just wonderin what kinda box are they in and what amp you got on them?
My last install was 2 12w6v2s in a H.O. JL box for 2 W3s,box was too small.But they got crazy loud,with around 500watts a piece goin to them.I would stick with the w6v2s.Good choice.
Old Dec 1, 2005 | 01:07 PM
SD1222's Avatar
Default Re: (Skip01)
i have them in a ported box that's how i bought them. Would a sealed box be better? Im using a zapco 1100.1 to power the subs.
Old Dec 1, 2005 | 02:40 PM
Skip01's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm_spoonEG &raquo;</TD></TR><TR><TD CLASS="quote">i have them in a ported box that's how i bought them. Would a sealed box be better? Im using a zapco 1100.1 to power the subs. </TD></TR></TABLE>
Ported will always be louder and if built right sound better,imo.Some people just go with sealed because its easier to build and takes up less space.But i find that JL subs sound good in pretty much any box you throw them in,ported or sealed.
Old Dec 1, 2005 | 10:01 PM
Sex Cells's Avatar
Default Re: (GSteg)
w6 sound alot better but the w7 has more potential to get loud, slap a 1000 watts to each and they'll ****
very nice amp by the way. Ported will get louder, but if you think ported sounds better you're a fool. sealed for sq all the way
Old Dec 1, 2005 | 10:38 PM
SD1222's Avatar
Default Re: (Eugenics)
^^^ i want some low deep bass so ported will be better right?
Old Dec 1, 2005 | 10:47 PM
Sex Cells's Avatar
nah, sealed typically gets lower and deeper, ported tends to be more boomy and loud. with that said a very well designed ported enclosure can sound decnent while being loud. but its not going to sound as good as a sealed box in a proper install. box design matters just as much as the sub. if your going sealed goto the companys specs. if you're going ported theres a wide range of options to get the desired results. when building a box use some 3/4mdf and calking and DONT BUY PREFAB BOXES
i have a great design for a W6v2 enclosure if anyone wants it
Sex Cells's Avatar
whats more imporant to you? sound quality or being loud? or somewhere inbetween?
Old Dec 1, 2005 | 10:57 PM
SD1222's Avatar
somewhere in between. Im not looking to go all out on the audio side just something that will sound decent with some good low deep bass
Old Dec 1, 2005 | 11:17 PM
Sex Cells's Avatar
personally i'd get an idmax, sounds as good (some argue better, but the w6v2 is well known as one of the best sq drivers) as the w6v2 and gets alot louder. wont rape your pocket book like the w7 will either
Old Dec 1, 2005 | 11:21 PM
SD1222's Avatar
i pm u about the w6v2 box design i was wondering can u make the box?
Old Dec 1, 2005 | 11:36 PM
Sex Cells's Avatar
replyed
Old Dec 2, 2005 | 08:29 AM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm_spoonEG &raquo;</TD></TR><TR><TD CLASS="quote">cool i'll stick with my 2 12' w6v2 then, thanks for the input </TD></TR></TABLE>Sorry, I missed that on your first post, you have 2 12" W6V2s, but again stick with the W6V2-D4s 94
EG-SIXV-TEC
Audio / Security / Video
16
May 8, 2014 09:53 AM
neonoodle
Nov 24, 2007 03:30 PM
astroxtc
Oct 11, 2005 06:51 AM
SoCal ITR
Apr 1, 2004 05:12 PM
Calavera
Mar 5, 2002 08:42 PM
