Another What Camber kit for my Civic.
Ok Im going to be rockin JLB's ksport 36 way adjustable coilover suspension. I plan on riding on a 3" drop and Im stuck on what camber kit to buy. Yes ive searched and searched but didnt find anything helpful. What i wanted to know is if i purchased a ingalls or spc adjustable ball joint what one will work best the 1.5 to 3+ or 0 to 1.5+ please help guys any tips suggestions or comments please
Modified by EM1_00MRBuilt at 4:51 AM 12/1/2005
ingalls would be best cuzz ball joints dont move much or u can go with a skunk2 camber kit . i thinkthere the best .thats what im running on my eg there the full a-arm and they will fix the camber down to a 3 1/2' drop maybe more just my 2cents
Im little bit hesistant to go with a full a arm set up because i dont want to take any chance at it slamming in to my fender wall. But i didnt ask wether to go with spc or ingalls but what one they offer a 0 to 1.5+ correction or a 1.5 to 3+ thanks for advice though
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EM1_00MRBuilt »</TD></TR><TR><TD CLASS="quote">
i think everything out in the market right now offeres -3 to +3. i'm planning to get ether the junk2 or the ingalls. been researching for a bit and saving so yeah.
</TD></TR></TABLE>i think everything out in the market right now offeres -3 to +3. i'm planning to get ether the junk2 or the ingalls. been researching for a bit and saving so yeah.
MY CAR IS ALO A 3 INCH DROP, IM USING INGALLS, 1 DEGREE IN THE FRONT AND 3 WASHERS ON THE REAR, FRONT STILL CAMBER A LITTLE BUT I FIGURED ITS OK CUZ YOU NEED A LITTLE FOR CORNERING
Good deal mang im also prolly going to use ingalls washer kit for the rear cheap and easy. So Do you think if you had the 3+ ingalls kit it would be to much? And have you got any alignment charts with 0-1.5+ kit you have thanks man
3+ ingalls is too much, mines 1+ or 1.5+ and im only using the 1+... ihave charts from the shop when i got it aligned...i say if your doing a 3 inch drop, 1.5-2+ degree is the good..
CAMBER IS WAY OFF!!!!!!! which camber kit well fix this ???????????? BEST CAMBER KIT OUT THERE??????
Kangolbrand
Suspension & Brakes
17
Mar 30, 2006 02:15 PM
