Wires and bulb sockets got all wet, will it be OK?
Old Nov 30, 2005 | 04:14 PM
For_Sale's Avatar
Default Wires and bulb sockets got all wet, will it be OK?
I got a stripped civic shell and its been sitting outside for a while. It been stormed on by the rain, and much of the wires/sockets got wet. For example, the rear tail light bulbs are missing, therefore the sockets got wet.
I've never worked on electrical that much, so I'm very very clueless. Assuming that everything dries up, Will things like those rear tail light bulb sockets be OK? Or will I need to replace the wiring systems and sockets?
thanks guys/gals
Old Nov 30, 2005 | 11:18 PM
john666's Avatar
Default Re: Wires and bulb sockets got all wet, will it be OK? (junkyard_turbO)
im ghetto so my answer mite be bad but. if everything dries i would think it would all be fine, perhaps clean the connections if possible since rust or whatever mite pop up. and i would recommend perhaps covering your car next time.
Old Dec 1, 2005 | 04:30 AM
For_Sale's Avatar
Default Re: Wires and bulb sockets got all wet, will it be OK? (john666)
ok, clean the connections to try and stop rusting.
but other than that, it wouldnt cause an electrical short or anything, would it? thats my biggest concern.
Old Dec 1, 2005 | 06:12 AM
92ehatch's Avatar
if there was no battery hooked up to the wiring then it cant short out.
just make sure you dry it up
Old Dec 1, 2005 | 07:42 AM
fcm's Avatar
fcm
Old Fart
As long as it's dry and cleaned you will not have a problem.
Hint.... To clean the sockets dip the whole thing into a glass of water and baking soda, then dry off, that works on batt. terms. also, but on a batt. just pour it on the term. 94
accordinglyevil
May 1, 2007 07:22 PM
For_Sale
Dec 1, 2005 05:43 AM
RedHackBatch
Jul 6, 2004 09:39 PM
Mr.Fairlady
May 6, 2004 03:25 AM
