car jumps at 3000 rpm
Old Nov 30, 2005 | 01:43 PM
ls_4dr_civic's Avatar
Default car jumps at 3000 rpm
when im driving my car its fine until i get up to 3000 rpm then it starts jerking and wont get past it plus my check engine light is on and if i let the car idle after a while the engine light will cut on whats the problem
what is tps and what should i look for on the red lights of the ecu
Modified by ls_4dr_civic at 4:15 PM 11/30/2005
Old Nov 30, 2005 | 02:06 PM
mattie_96's Avatar
pull the carpet back on the passenger side footwell....how many red flashes are there for from the ECU?
Old Nov 30, 2005 | 02:11 PM
boost'd_crx's Avatar
Default Re: car jumps at 3000 rpm (ls_4dr_civic)
check the tps
Old Dec 1, 2005 | 09:43 PM
sleeperrex's Avatar
Default Re: car jumps at 3000 rpm (boost'd_crx)
hahhaha you are only running on three cylinders. check that ur wires are connected to ur spark plugs good and into ur cap. you might need a new cap and rotor. plus check ur spark plugs too
Old Dec 3, 2005 | 10:50 AM
InEK's Avatar
when you turn the car on does the idle fluctuate? whens the last time youve done a tune up? are you getting fuel through the lines? Have you replaced your fuel filter? It could be many things...ur best bet is finding out why the check engine light is on..thatll tell you if you have a cylinder misfire or if its something else...
97honda_accord
Mar 16, 2015 08:46 PM
WanaBeFaster
Mar 4, 2013 03:34 PM
93 DET
Feb 14, 2012 12:36 PM
eric94si
Oct 17, 2011 09:53 AM
CUTTERSPOOL
Jul 16, 2009 06:05 AM
