need help removing b16 1st gen knock sensor PLEASE HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Nov 30, 2005 | 01:11 PM
88cerx's Avatar
Default need help removing b16 1st gen knock sensor PLEASE HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!!
im trying to remove the stock knock sensor and replace it with a good workging one out of a 2000 si but dont know what size socket i need i know the 2000 si one is a 27mm but the 1st gen is def smaller any help would b great
Old Nov 30, 2005 | 01:20 PM
SD_Lurker's Avatar
HT White Ops
Default Re: need help removing b16 1st gen knock sensor PLEASE HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!! (88cerx)
its also a 27
Old Nov 30, 2005 | 03:43 PM
88cerx's Avatar
Default Re: need help removing b16 1st gen knock sensor PLEASE HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!! (nicks_jdmst
are you sure cuz it seems not to fit when i put the ratchet on it.. the 1st gen sensor seems to be smaller
Old Nov 30, 2005 | 04:08 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
Looking at an engine I have in my shop,
The knock sensor is so close to the intake manifold,
The socket I have won't go all the way on..
Need a really thin socket or maybe grind one down....
Old Nov 30, 2005 | 04:20 PM
88cerx's Avatar
could be it???????????
Old Dec 1, 2005 | 12:46 AM
Blue Hybrid's Avatar
use a combination wrench turn up ways, put a screwdriver thru the box side of the combo wrench, then turn it
Old Dec 1, 2005 | 04:34 AM
88cerx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gold EF &raquo;</TD></TR><TR><TD CLASS="quote">use a combination wrench turn up ways, put a screwdriver thru the box side of the combo wrench, then turn it </TD></TR></TABLE> say whjat
Old Dec 1, 2005 | 02:46 PM
88cerx's Avatar
i figured it out i was trying to use a impact socket but was to thick so i bought a crapsman and it fit mint all set thanks for the help
Excelerate
Nov 15, 2003 12:01 AM
krazyDOHC
Sep 16, 2003 09:32 PM
AustinTXRules
Jul 25, 2001 07:28 PM
