60mm Exhaust + 2.5'' Cat, will they bolt up?
Old Nov 30, 2005 | 01:08 PM
paopao's Avatar
Default 60mm Exhaust + 2.5'' Cat, will they bolt up?
I'm going to be putting on a complete exhaust system in a couple of days. I just ordered a 2.5'' Carsound cat, and the cat back is a 60mm Greddy exhaust. If I get a 3 bolt flange welded to the Carsound cat, will they bolt up?
I'm not worried about the header side of the cat because it will use a 2.5'' collector that should bolt up nicely to my AN-R header.
Old Nov 30, 2005 | 01:25 PM
Keith P's Avatar
Default Re: 60mm Exhaust + 2.5'' Cat, will they bolt up? (paopao)
It should be fine. there is only a 0.138" difference. Worse case you may need to hog out the holes a little. My last two greddy exhausts bolted on with out any issues.
Old Nov 30, 2005 | 01:50 PM
NCchris's Avatar
Default Re: 60mm Exhaust + 2.5'' Cat, will they bolt up? (Keith P)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Keith P &raquo;</TD></TR><TR><TD CLASS="quote">It should be fine. there is only a 0.138" difference. Worse case you may need to hog out the holes a little. My last two greddy exhausts bolted on with out any issues.</TD></TR></TABLE>
My Greddy MX bolted up fine but I used a 2-1/4" carsound cat and welded on my own flanges. Check the exhaust hole size in the Greddy 3-hole flange mine was much smaller than the ID of the exhaust. I assume this was to fit a stock cat. A little work here with a grinder can remove quite a bottleneck.
HTH
chris
Old Nov 30, 2005 | 02:23 PM
paopao's Avatar
Default Re: 60mm Exhaust + 2.5'' Cat, will they bolt up? (NCchris)
Thanks for all the replies. I'm gonna try my luck w/2.5'' 3 bolt flange then. Hopefully the difference is negligable.
mannydhanju
Mar 29, 2009 10:53 AM
1998teg
Aug 23, 2004 03:59 PM
Gump
Apr 11, 2003 01:03 AM
Aaron M
Feb 18, 2003 12:35 AM
redteg1
Dec 15, 2001 12:57 PM
