how do i know when is 3 teeth when i turn the crank case for 3 teeth?
Old Nov 30, 2005 | 11:02 AM
lv6l's Avatar
Default how do i know when is 3 teeth when i turn the crank case for 3 teeth?
i'm trying to adjust my tensioner and belt but i want to know how do i know when is 3 teeth when i turn the crank case for 3 teeth? do i turn the crank pully 3 teeth or the cam gear 3 teeth?
94 hatch cx. stock everything. thanks.
Old Nov 30, 2005 | 11:31 AM
IHateJDM's Avatar
Default Re: how do i know when is 3 teeth when i turn the crank case for 3 teeth? (lv6l)
3 teeth usually refers to the distance of rotating 3 teeth of the cam gear(s). that's not an accurate way to set your timing though. When you adjust the tensioner, you should manually turn the crank at least 3 full engine rotations before you start it. that gives the tensioner time to tighten up.
Dom93
64
Jan 18, 2012 07:09 AM
Civicman86
Jun 22, 2006 10:01 AM
JRciv
Nov 22, 2004 01:58 PM
spyderracing
14
Sep 26, 2004 09:10 AM
david90
Aug 14, 2003 09:48 AM
