Swapping a Autp trans EG to Manual? Yes I search, is it worth it? and a question on mounts
Old Nov 30, 2005 | 07:56 AM
DREID's Avatar
Default a question on mounts
with mounts, do they bolt in and then I can have them welded or do I need to attach them to the motor, set the motor in place and go from there. I hope I can just bolt and weld them in.
motor would be ls vtec in a eg hatch
Old Nov 30, 2005 | 08:57 AM
Kendall's Avatar
Hasport makes a mount that enables you to do it without cutting and welding. From there it's just sourcing the rest of the necessary parts.
Old Nov 30, 2005 | 10:46 AM
Andres-eh2's Avatar
In automatic cars the top tranny mount chassis bracket sits differently than a manual car so you do need that mount as stated above. Then just get the nexccesary bseries mounts. You also need a slave cylinder along with the lines, pedal assembly etc
Old Dec 1, 2005 | 03:56 PM
cybergreencivic's Avatar
Default Re: (Andres-eh2)
the mount on the frame on the passenger side sits further out from the fire wall on a manual. the place i had to my swap just cut it and welded it further out. on the drive home from that shop, it broke. so i had to order a new one from Honda, and have the old one cut of and new one re-welded in. i havent heard anyone else having any similar problem with their auto to manual conversion, but that was my main issue.
Old Dec 5, 2005 | 03:24 PM
sixspeeddemon's Avatar
how hard is it to do the wiring conversion to make the auto to manual work...sorry i'm new to honda-tech...i'm building up a k20a2 on a=n auto chassis and i believe that's the only thing holding me up...any help would be great...
Rttix1337
Feb 9, 2014 06:23 AM
jdmh22eg2
Transmission & Drivetrain
Jan 4, 2013 03:51 AM
shoklid
Jul 1, 2009 11:39 AM
the4g4d
Jan 31, 2007 10:20 AM
Pompiuses
Jun 12, 2006 11:26 PM
