clutch master and slave cylinder questions
Old Nov 30, 2005 | 05:53 AM
96ls's Avatar
Default clutch master and slave cylinder questions
i am installing a new type r trans this weekend and was curious if there are stock replacement clutch master and slave cylinders that are bigger than the ones that came stock on my 93 si?
Old Nov 30, 2005 | 05:54 AM
litterbox's Avatar
I am a (Trial User) Army
Default Re: clutch master and slave cylinder questions (96ls)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96ls &raquo;</TD></TR><TR><TD CLASS="quote">i am installing a new type r trans this weekend and was curious if there are stock replacement clutch master and slave cylinders that are bigger than the ones that came stock on my 93 si?</TD></TR></TABLE>
Civic and Integra ones are both 5/8ths but I recently heard that Prelude MC's are bigger and might work. Look into that..
Old Nov 30, 2005 | 05:55 AM
96ls's Avatar
Default Re: clutch master and slave cylinder questions (litterbox)
are the slave cylinders the same from civic to integras
Old Nov 30, 2005 | 05:56 AM
litterbox's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96ls &raquo;</TD></TR><TR><TD CLASS="quote">are the slave cylinders the same from civic to integras</TD></TR></TABLE>The correct question would be if B or D slave cylinders have a different bore. Not sure of the answer, hell, I don't even know if you can use a D slave on a B tranny or vice versa. I'm guessing no.
Old Nov 30, 2005 | 05:58 AM
96ls's Avatar
thanks for the help!
and to answer your question the d series slaves will bolt up and work on a b series trans
Old Nov 30, 2005 | 05:59 AM
litterbox's Avatar
Cool.
MoogieBoogie
17
Aug 12, 2013 11:53 AM
ZenDynasty
24
Jun 1, 2008 07:56 PM
Stillo
Oct 24, 2007 04:57 PM
hip_hop_s0ulchild
Oct 22, 2005 01:35 PM
TurblowR
Mar 28, 2005 06:26 PM
