ls crank in b18c1
Old Nov 29, 2005 | 11:24 PM
allinone07860's Avatar
Default ls crank in b18c1
just confused about the whole ls crank and the b18c1
i have a gsr the rod baring went out
ive heard that people put b18a1 internals into a b18c1 just wondering how that works do u need to bore the block does it fit right in any help would be great also new to the site
Old Nov 30, 2005 | 12:04 AM
The Tea-father's Avatar
Default Re: ls crank in b18c1 (allinone07860)
You can use LS crank in a b18c block, and have to use the ls rod also, piston you can use either or depends how the compression you like to achived. LS crank in a b18c block with give a bigger stroke more TQ
Old Dec 5, 2005 | 08:35 PM
Default Re: ls crank in b18c1 (The Tea-father)
thanks alot ur imput help out alot i just switched from a 11 sec ford hopeing to get the integra into the 11 also
Old Dec 6, 2005 | 12:54 AM
good luck welcome to the Honda community, i used to have a few mustangs back in the day as well
Old Dec 6, 2005 | 05:51 AM
veggiemaster's Avatar
but you will also loose the ability to rev as high. the LS crank isnt balanced like the GSR crank.
Old Dec 6, 2005 | 07:12 AM
Kendall's Avatar
Default Re: ls crank in b18c1 (veggiemaster)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by veggiemaster &raquo;</TD></TR><TR><TD CLASS="quote">the LS crank isnt balanced like the GSR crank.</TD></TR></TABLE>
Which is precisely why you should have the rotating assembly balanced prior to installation.
Old Dec 6, 2005 | 08:15 AM
Default Re: ls crank in b18c1 (Kendall)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kendall &raquo;</TD></TR><TR><TD CLASS="quote">
Which is precisely why you should have the rotating assembly balanced prior to installation.</TD></TR></TABLE>
exactly, we rev our ls crank to 10k all the time
Old Dec 7, 2005 | 10:39 PM
the guy at the machine shop said that ill have a 9 to 1 compression stock everything souuld i put some ctr cams and skunk 2 intake manifold
Old Dec 7, 2005 | 11:00 PM
Lauj87's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allinone07860 &raquo;</TD></TR><TR><TD CLASS="quote">the guy at the machine shop said that ill have a 9 to 1 compression stock everything souuld i put some ctr cams and skunk 2 intake manifold</TD></TR></TABLE>
if its on a GS-R block its more like a 11:1 compression ratio, its a longer stroke and with ls Rods and GS-R pistions i don't think the compression is going to drop at all..but i could be wrong.
Old Dec 8, 2005 | 05:11 AM
Default Re: ls crank in b18c1 (Lauj87)
This will give you your CR http://www.turbofast.com.au/Tfcomp.html
Old Dec 8, 2005 | 07:40 AM
Muckman's Avatar
Moderator in Chief
The rod length difference is equal to the difference in stroke, there is no difference in piston wrist pin height. therefore compression would remain the same with the same piston. I also use a LS crank in my fully built GSR motor.
joedeezy
Oct 18, 2008 02:53 PM
Civic92Turbo
Mar 4, 2007 06:41 PM
ProjectBoosted
Oct 23, 2006 10:02 AM
Nextelbuddy
11
Jun 4, 2003 03:11 PM
