Del Sol fitment inquiries: Air conditioning and Gauge cluster
Can anyone tell me if the blower assembly from under the dash of a 1994 Civic Ex coupe will directly fit into a 1993 Del Sol Si. The Del Sol's air conditioner has been cannibalized, but I have the complete 134A system from a 1994 Coupe. Can anyone tell me if I can directly swap this in? If not, what kind of issues am I looking at.
The Del Sol I purchased does not have a gauge cluster. I have found a 1996 Del Sol Si 5 speed cluster. Does anyone know if this would be plug and play? I have been told the redline is different. Any insight if this may be an issue? Can anyone tell me what years of Del Sols used a cluster exactly like the 1993 w/ a 5 speed. It's rather hard to drive the vehicle with no tach or speedo, and I would like them to be accurate.
I would appreciate any kind of knowledgeable answers to my questions.
The gauge cluster should fit without issue. If you have a 93 Si, and it's from a 96 Si, they should have the same redline. Now that I think about it, the 93 Si might have had a 7,200 redline while the 96 would have a 6,800? I'm not positive on the redline issue, but I don't see any reason why it wouldn't fit.
I have no idea on the blower.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ****** »</TD></TR><TR><TD CLASS="quote"> I don't see any reason why it wouldn't fit.</TD></TR></TABLE>
well, the thought that b/c the 96 is obd2 vs the 93 being obd1, the wiring might be different.
thanks for the reply.
anyone else have some ideas?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by qat727 »</TD></TR><TR><TD CLASS="quote">
This might be true, I'm not sure. Bump for you though.
They should be the same, I have a cluster from a 93 del Si if your interested, its not in the best shape but the houseing on it would be fine if you need it.
Bump it up for some answers. Someone has to have parted out a del sol and knows what the A/C housing looks like. And what about all those OBD gurus around?
DelCarajo
18
Jan 8, 2015 03:21 PM
rusteds2k
Jan 31, 2003 03:54 PM
