D16Y8 IN EF NOT STARTING!
Old Nov 29, 2005 | 10:45 PM
beaneg6's Avatar
Default D16Y8 IN EF NOT STARTING!
timing is correct,spark fuel everything is there...is there anything i am missing????
pm6 ecu non vtec
obd 2 fuel rail
stock si injectors
91 si ef
why isnt it starting???
91 si dizzy
91 si harness
obd2 d16y8
come on guys whats wrong???help me out!!!
Old Nov 29, 2005 | 11:02 PM
boylovecar's Avatar
Default Re: D16Y8 IN EF NOT STARTING! (beaneg6)
does it turn over? and check your grounds,tranny,thermostat housing,alternator etc.
Old Nov 30, 2005 | 01:01 AM
beaneg6's Avatar
Default Re: D16Y8 IN EF NOT STARTING! (boylovecar)
turns over fine...all grounds are intact
Old Nov 30, 2005 | 02:09 AM
Orthello's Avatar
Spark Plug Wires mixed up?
Compression??
Spark power?
Old Dec 1, 2005 | 09:50 PM
sleeperrex's Avatar
Default Re: (Orthello)
yea check your firing order
Old Dec 1, 2005 | 10:37 PM
Rywire's Avatar
Default Re: (sleeperrex)
what dont u have? spark or fuel?
Old Dec 1, 2005 | 10:43 PM
VRD^sam's Avatar
Default Re: (droppedcrxsi)
need more info bro
Old Dec 2, 2005 | 01:32 AM
beaneg6's Avatar
Default Re: (jdm_madman)
there is spark,fuel,compression its all there...i really dont know why it isnt starting
34
12 firing order? correct me if i am wrong
Old Dec 2, 2005 | 02:57 AM
Orthello's Avatar
Old Dec 2, 2005 | 04:57 AM
spiceisler's Avatar
Was the head dissassembled or was the motor never opened?
Old Dec 2, 2005 | 07:08 PM
beaneg6's Avatar
Default Re: (spiceisler)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spiceisler &raquo;</TD></TR><TR><TD CLASS="quote">Was the head dissassembled or was the motor never opened?</TD></TR></TABLE>
no the motor came out of a running 98 ek coupe that went up to a b16 there is nothing wrong with it timing etc is perfect
Old Dec 2, 2005 | 07:56 PM
Fobtions's Avatar
Default Re: (beaneg6)
make sure u dont have the air injection on the injectors.
Old Dec 2, 2005 | 08:10 PM
ppfalcon's Avatar
Default Re: (Fobtions)
what distributor are you using?
ignitor might be bad?
Old Dec 2, 2005 | 10:39 PM
maRcus of EF squaD's Avatar
Default Re: (ppfalcon)
did you try push starting it?? juss a thought
Old Dec 3, 2005 | 12:06 AM
boylovecar's Avatar
check for spark in all cylinders. pull distibutor off and make sure the gear is matched up to the cam. there is a line on the dizzy and the cam. the line seems to be in the middle but if you look closely one side has more than the other. in other words you may have the dizzy on 180 degrees off which would throw your firing order off. good luck.
Old Dec 3, 2005 | 12:27 AM
beaneg6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fobtions &raquo;</TD></TR><TR><TD CLASS="quote">make sure u dont have the air injection on the injectors. </TD></TR></TABLE>
can somebody explain this?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boylovecar &raquo;</TD></TR><TR><TD CLASS="quote"> check for spark in all cylinders. pull distibutor off and make sure the gear is matched up to the cam. there is a line on the dizzy and the cam. the line seems to be in the middle but if you look closely one side has more than the other. in other words you may have the dizzy on 180 degrees off which would throw your firing order off. good luck.</TD></TR></TABLE>
there is spark
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ppfalcon &raquo;</TD></TR><TR><TD CLASS="quote">what distributor are you using?
ignitor might be bad?</TD></TR></TABLE>
the stock ef si dizzy...well the motor that was in the car was a zc single cam
Flaco argento
Jul 29, 2017 11:44 PM
Navy_Kyle
20
Jan 29, 2011 11:17 PM
Fullracejdm
Aug 29, 2010 11:42 PM
basktb1188
Aug 14, 2009 06:01 AM
lvzero0
Oct 27, 2005 06:20 PM
