Oh my!!!
Old Nov 29, 2005 | 10:08 PM
jononioo's Avatar
Default Oh my!!!
Can somebody tell me the paint code to the work CR rims. Im not sure if i can get the same results using the Dupli color 104 or dupli-color high perfromance wheel coating HWP105. I think the rim color is "sport bronze" but im not exacly sure. I have searched btw! Also what is the paint code to match the Rota C10 bronze rims! Thanks in advance!
Work CR
Rota C10
Old Nov 29, 2005 | 10:20 PM
jononioo's Avatar
Default Re: Oh my!!! (jononioo)
sports bronze seems to be alot darker than regular bronze...
Old Nov 30, 2005 | 06:04 AM
jononioo's Avatar
bump for me... thanks guys!
Old Nov 30, 2005 | 06:54 AM
Richard Noggin's Avatar
From: Good luck to this industry, you're gonna need it.
bump for an answer, I would LOVE to paint my mesh's that way....but I've never found anything I could get that dark with .
Old Dec 1, 2005 | 10:20 AM
jononioo's Avatar
bump!
Old Dec 1, 2005 | 11:19 AM
95lstegman's Avatar
Default Re: (jononioo)
put several light coats on. i put 2 coats of gray primer then 3 coats of gunmetal then 4 coats of clear on mine. after the first coat of gunmetal it was kinda light, but by the time the third was tacky and ready for the clear it was very dark. use layers and thickness of each layer to get the darkness you want. although if you're using a very light color to begin with, it's not going to get really dark. your other option is to put a black primer and then a very thin coat of a lighter bronze. then clear coat it well so the color doesn't get damaged.
b16 v8klr
May 10, 2009 12:12 PM
j87w
Jul 13, 2005 01:00 AM
PolyPill
Feb 20, 2005 08:05 AM
Xgen
Jul 14, 2004 07:58 PM
