Brakes loosing pressure 91 DA
Old Nov 29, 2005 | 07:21 PM
Gimpo's Avatar
Default Brakes loosing pressure 91 DA
i just put installed Brembo cross drilled rotars and ceramic pads all around and now when i drive the car my brakes have no prssure(the pedle goes to the floor) but i can pump the vrake while i'm driving and get soem prssure back, i've bled the brake system about 4 times and then took it to a friend to make sure i wasn't doing it worng, anyone have an other ideas? maybe the brake booster or master cylinder??
Old Nov 29, 2005 | 08:18 PM
Gimpo's Avatar
Default Re: Brakes loosing pressure 91 DA (Gimpo)
up before bed.
Old Nov 29, 2005 | 08:36 PM
og asr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Gimpo &raquo;</TD></TR><TR><TD CLASS="quote">i just put installed Brembo cross drilled rotars and ceramic pads all around and now when i drive the car my brakes have no prssure(the pedle goes to the floor) but i can pump the vrake while i'm driving and get soem prssure back, i've bled the brake system about 4 times and then took it to a friend to make sure i wasn't doing it worng, anyone have an other ideas? maybe the brake booster or master cylinder??</TD></TR></TABLE>
Change your master cylinder........this happened to my DA.
Old Nov 29, 2005 | 09:02 PM
Danronian's Avatar
I 2nd the master cylinder. Same thing happened on my teg.
Old Nov 29, 2005 | 10:35 PM
jaymua's Avatar
same here happend to me too change the masteer cylinder :D
Old Nov 30, 2005 | 10:53 AM
Gimpo's Avatar
Default Re: (jaymua)
awesome, wil do this weekend. not sure if it changes anythnig but i forgot to add that if i pull the ebrake the rear locks
Old Nov 30, 2005 | 10:57 AM
89 pos's Avatar
Default Re: (Gimpo)
check your brake lines first i had that same prolem you might save some money i wish i had checked mine before i replaced my master cylender it ended up being the brake lines
stillrockin18s's Avatar
Had the same problem..
I changed the master cyl. and still had the same problem. I changed the brake booster and that fixed the problem..
When you are stopped at a stop sign with your brakes depressed do you notice a change in the idle?
Old Nov 30, 2005 | 03:31 PM
Gimpo's Avatar
Default Re: Brakes loosing pressure 91 DA (lowriden_acura)
yes idle is low almost stalling low
Old Nov 30, 2005 | 03:41 PM
Gimpo's Avatar
also what do you mean by brake lines? you mean leaks? i don't have any checked last night and this morning, it's been in the garage since sunday
Old Dec 1, 2005 | 02:05 AM
I would DEFINITALY check out the brake booster if your idle is dropping at a stop. The idles may be dropping because of the vaccum pressure coming out of the booster.
Old Dec 1, 2005 | 06:15 AM
92integraVTECgsr's Avatar
hmm.. I just changed my Brake MC a few ago... brakes a soft, but still work.
but my idle drops to the point of stalling when im at the stoplight or a complete stop with the brakes in use.
so i guess my brake booster needs to be replaced too..
Old Dec 1, 2005 | 06:52 AM
Default Re: Brakes loosing pressure 91 DA (92integraVTECgsr)
92integraVTECgsr - Sent you a LONG PM homie
Old Dec 1, 2005 | 07:49 AM
thanks. i got it..
im probably just gonna replace the brake booster.. but its cold outside.. so i might hold off for abit.
Kennyjai
Nov 28, 2012 12:00 PM
chris3k
Nov 2, 2008 08:05 PM
in10ceCiviC
Feb 1, 2007 10:58 AM
dropt
Feb 9, 2005 04:52 AM
Rboosted717
Aug 1, 2001 12:14 PM
