HELP!?!?!?!?!!
Old Nov 29, 2005 | 04:15 PM
90civSi's Avatar
Default HELP!?!?!?!?!!
i am changing the timing belt in a b16a1 that just came in from Hmotors, i counted the teeth on the timing belt that came on it and the teeth of the new belt but also. the belt i got is for a del sol 97 i believe and its a b16a2. after i removed the old belt, and put the new one on, i realized that its very loose? they are the same thing. i roated the crank 2 times and put it back at TDC and it didnt jump a tooth, its just loose, and has some "sag" at the top b/w the 2 cam gears?.... any idea..
Old Nov 29, 2005 | 04:21 PM
90civSi's Avatar
Default Re: HELP!?!?!?!?!! (90civSi)
bump
Old Nov 29, 2005 | 07:55 PM
boylovecar's Avatar
i'd check w/ the tensioner. but if you don't know what you're doing, paying a pro to do it is pretty good insurance on your newly purchased motor. if you want to learn how to do it then ask till you find someone who will share the knowledge. don't expect to get everything for free, cut corners where you can, but not at the risk of your motor.
Old Nov 29, 2005 | 08:05 PM
RCautoworks's Avatar
Try pulling up on the tensioner ( use a coat hanger ) and then retighten the tensioner.
Sometimes the tensioner will not put enough tension on it.
Old Nov 30, 2005 | 06:47 AM
integra95gsr's Avatar
yeah it was the tensioner not putting enough "tension" on the belt. all is well now!
blakh
10
May 7, 2007 10:09 AM
Panoply
May 12, 2006 12:05 PM
huge230
Oct 4, 2005 12:31 PM
1SlowSi
Feb 6, 2005 04:39 PM
johnzm
Jun 16, 2002 06:56 PM
