Fixing my AC 2000 Civic
Old Nov 29, 2005 | 04:10 PM
zero808's Avatar
Default Fixing my AC 2000 Civic
hi, so i bought a 2000 EX (d16y8) with everything working, until i realized the AC wasnt working. the guy I bought it from said it just needed a recharge; i recharged it, but the AC still blew warm air.
at night, the air gets cooler from the vents, but not cold. i was wondering, does anyone know the problem? is it the condensor or the compressor? has anyone ever tried replacing either of these parts at home? i can get the system vacuumed, but im just wondering what kind of work is involved. is it just better to take it down to my local honda dealership? thanks
Old Nov 29, 2005 | 05:41 PM
95dxhatch's Avatar
did you check to make sure the compressor clutch was engaging when you hit the AC button?
Old Nov 30, 2005 | 04:18 AM
john666's Avatar
Default Re: Fixing my AC 2000 Civic (zero808)
did you check if there was a leak or a pinch in your ac line.
Old Nov 30, 2005 | 04:55 AM
snatch's Avatar
Default Re: Fixing my AC 2000 Civic (john666)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95dxhatch &raquo;</TD></TR><TR><TD CLASS="quote">did you check to make sure the compressor clutch was engaging when you hit the AC button?</TD></TR></TABLE>
Check this first. Should be an audible click when the clutch engages.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by john666 &raquo;</TD></TR><TR><TD CLASS="quote">did you check if there was a leak or a pinch in your ac line. </TD></TR></TABLE>
Check this next, just to be certain.
If nothing else, follow this DIY. I did it last weekend, A/C blows in the high 30's right around 40 degrees.
http://www.d-series.org/forums...26051
PL_RACER
Honda Civic (2006 - 2015)
Jul 24, 2012 07:20 PM
xxjokoxx
Aug 23, 2010 12:51 AM
D16SohcVtec
Jul 28, 2009 07:38 PM
vietnogi
May 24, 2005 08:01 AM
HNLV
Apr 6, 2005 01:42 AM
