Anyone ever install a set of H&R Coilovers on their EG/92-95 civic?
Old Nov 29, 2005 | 02:46 PM
EnjoyTheRideDC2's Avatar
Default Anyone ever install a set of H&R Coilovers on their EG/92-95 civic?
To those who have installed or participated in an install on a 92-95 Civic w/H&R Coilovers, must the spring be compressed in order to secure the top hat onto the strut, or can you assemble the whole strut assembly without it being compressed? Just need to know if I need to get my hands on a compressor or not before my coils come in. Any help is appreciated.
Old Nov 29, 2005 | 03:02 PM
blanco617's Avatar
Default Re: Anyone ever install a set of H&R Coilovers on their EG/92-95 civic? (EnjoyTheRideDC2)
are they lowered springss or factory settings if they are lowerd then you shouldnt need to compress because they are shorter
Old Nov 29, 2005 | 03:06 PM
Default Re: Anyone ever install a set of H&R Coilovers on their EG/92-95 civic? (blanco617)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blanco617 &raquo;</TD></TR><TR><TD CLASS="quote">are they lowered springss or factory settings if they are lowerd then you shouldnt need to compress because they are shorter</TD></TR></TABLE>
They're full on coilovers, so whatever spec spring and shock they use with their setup. The only reason why I'm specifc about these coilovers is because i've been told there is a preload once the coil has been put together. I dont know if that alters anything or what.
Old Nov 30, 2005 | 02:34 PM
In case anyone ever wonders about the question I initially asked in this thread, the answer is : YES YOU DO NEED A SPRING COMPRESSOR.
emooheo
Suspension & Brakes
Feb 28, 2007 05:13 PM
JoshuaVTEC
Suspension & Brakes
Mar 5, 2006 06:43 PM
Spoogen_1
Feb 13, 2006 03:03 PM
EKhybrid
Suspension & Brakes
Oct 13, 2005 01:03 PM
B-Series Sol
Aug 27, 2002 02:23 PM
