BLOWN!!!! Diff??????
Old Nov 29, 2005 | 02:30 PM
dkboyny11's Avatar
Default BLOWN!!!! Diff??????
I have a realy bad noise coming from either the trans for what I thought at first to be the passenger axle. It sounds like something is skipping in the trans when I load the diff. Does this mean the diff is toast????? I replaced the axle with another unit and it has the same problem as before. I need some way to check if that is the definite problem before I go and buy an expensive differential. I have a Y1 trans with a quaiffe. Any help is appreciated.
Old Nov 29, 2005 | 05:20 PM
Lo-Buck EF's Avatar
well, quaife diffs have lifetime waranty. so if it is, send it back and get a fresh unit. but it sounds like it may be sonething else.
Old Nov 30, 2005 | 11:43 AM
dkboyny11's Avatar
Default Re: (Lo-Buck EF)
Thanks for the heads up on the lifetime warranty thing
da9bigboi
Transmission & Drivetrain
Feb 28, 2012 09:30 PM
fortymcpants
Oct 27, 2008 04:00 PM
LANEVOIX
Mar 4, 2005 11:20 AM
ih8sndq
Dec 24, 2004 03:17 AM
IntegraFanatic
Apr 22, 2004 07:32 PM
