Stock Intake
I have a stock intake with a K&N drop-in filter and was wondering if it is worth the investment to get an aftermarket one. I have seen a lot of people with stock intakes with their swaps, what are some pro's and con's of the stock intakes?
Show Car??? Buy it if you want looks under your hood. Make it if you dont. Defently better then stock. Not worth the money.
Go here:
http://store.summitracing.com/defaul...rchType%3DBoth
Buy one of these cut it up in the bends you need. Weld it all up ( Get someone to do this if you dont got a welder) Grind down the welds, sand and then polish or poadercoat. Get 3" piping though and get the filter first to see how it will attach. The filter has to be a cone one obviously. Dont forget the vacum line on it you have to drill a hole for that. Look at several aftermarket ones to get the vacum line placment
my 2 cents
Go here:
my 2 cents
From: PhantomGrayEH2, CA Where Gay Arnold Rules, USA
I have the same set up in my CRX and I took that pipe and left a big hole in my box. Sounds good, and it seems to pull a little harder.
The stock airbox is not very good for making any kind of power. Not only is it quite restrictive. But the filter area is WAYY too small. You will notice good gains with any good aftermarket intake. Especially a cold air intake.
Guest
Posts: n/a
ah i've seen Locash's (from HASport) dyno plots on when he tested the same motor setup, one with K&N stock airbox and one with underhood intake, and they were identical and if i remember, i think the airbox came out a little more powerful than the conical filter.
plus the airbox is a hell of a lot cleaner looking.
JMO
JMO
sfdc5rsx1
10
Apr 6, 2007 04:50 PM
SIK IN DA HED
Jun 2, 2004 12:08 PM
Razor
Jul 18, 2002 05:12 AM
slimbo
Feb 25, 2002 07:56 AM
