helllllllllllpppp dizzy problems
i did a head swap on my d15b6 to a d15b2 head and my dizzy is 180 degrees from tdc what do i do the head is in sync at tdc and the dizzy is 180 the other way what do i do
Turn it 180 deg and bolt it on. If you cant do that cause something is in the way, your going to have to chop off a leg so that it will fit. This is common practice for some people who want to use a non-vtec dizzy on a VTEC head, or so Ive herd.
Blaze
Blaze
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blaze45 »</TD></TR><TR><TD CLASS="quote">Turn it 180 deg and bolt it on. If you cant do that cause something is in the way, your going to have to chop off a leg so that it will fit. This is common practice for some people who want to use a non-vtec dizzy on a VTEC head, or so Ive herd.
Blaze</TD></TR></TABLE>
what do u mean by cut the leg off?
look at the dizzy gear facing you, there should be a line in between it. it won't be directly in the center ,now line that up with that same line that's on your cam. peer inside head to see,you may need lighting. if the bolt pattern for the dizzy doesn't line up,don't be ghetto fab,just get the appropiate dizzy. they'a dime a dozen.
kr3wkid420
Sep 23, 2015 07:01 PM
tangerinebeast
Mar 24, 2011 04:19 PM
underdog_racer
Sep 1, 2007 08:30 AM
h22turbofiend
Feb 6, 2007 07:47 PM
