Help installing REAR speakers in a 1994 Civic EX coupe
Old Nov 29, 2005 | 01:00 PM
E36 Guy's Avatar
Default Help installing REAR speakers in a 1994 Civic EX coupe
Hey I can't figure out how to remove the rear speaker grill. Can someone help me?
Also, would I blow a speaker if I mixed the positive and negative wires up? Because I cant figure out which wire is which. Thanks guys.
Old Nov 29, 2005 | 02:42 PM
92ehatch's Avatar
Default Re: Help installing REAR speakers in a 1994 Civic EX coupe (WHACK EG4)
in the trunk you have one of two things, either 3 bolts holding it on or 3 skrews.
if you have bolts its easy, i think a 10 mm or mabye a 9mm.
if it is skrews its a little more difficult.
there are gonna be 3 holes that are larger than the rest, if you look inside those then you will see a skrew in each one. easy to remove skrews, harder to put em back in
Old Nov 29, 2005 | 08:40 PM
boost'd_crx's Avatar
well you fold the rear seats down. then you can start taking off the big panel with the speaker covers on it ( they are not detachable) unhook the third brake light and pop off the clips and bolts that hold the panel in. with the wiring dont mix them up, it wouldnt sound the same.
flea4789
Jan 29, 2013 08:46 PM
E36 Guy
Nov 30, 2005 11:35 AM
Krut
Jan 24, 2005 07:48 PM
ImpoRTride
Audio / Security / Video
Nov 18, 2002 07:16 PM
CTL
Aug 22, 2002 06:57 PM
