tach install to the dizzy
Old Nov 29, 2005 | 11:59 AM
heyitzspikey's Avatar
Default tach install to the dizzy
okay i searched and cant find where the blue wire is located on the dizzy i know the green wire from the tach goes to the blue wire on the dizzy can any1 tell me which blue wires? my more is a b16 obd1 there have 1 blue wire and another one is it that one?
Old Nov 29, 2005 | 01:23 PM
EJ1 wilcox's Avatar
Default Re: tach install to the dizzy (heyitzspikey)
Just tap the blue wire from the back of your cluster or tap the RPM wire at the ECU.
No need to feed any wire through the firewall for a simple tach install.
Old Nov 29, 2005 | 01:44 PM
vegaskurt's Avatar
Default Re: tach install to the dizzy (EJ1 wilcox)
take the cap of your distributer and you will see a blue wire, on mine there was a " - " mark on it for negative. Thats the one you want.
Old Nov 29, 2005 | 02:31 PM
"tap the RPM wire at the ECU" what color is the wire?
Old Nov 29, 2005 | 03:06 PM
crxnj's Avatar
Default Re: (heyitzspikey)
Pin b15,,it's the white wire..And I think that's the wire that feeds the ignitor so it should be the most accurate..
Old Nov 29, 2005 | 03:45 PM
boost'd_crx's Avatar
you can find the blue tach wire on the big harness on the driver side connections in the engine bay.
Old Nov 29, 2005 | 05:23 PM
i have a obd1 i p28 box
civiclxb16a
Apr 30, 2005 09:37 PM
NeedACivic
May 7, 2003 01:57 PM
cw_civic
Audio / Security / Video
Jun 19, 2002 08:21 PM
cw_civic
Jun 17, 2002 11:32 PM
projectcrx
May 15, 2002 10:36 PM
