Does a 92-95 prelude s/si catalytic converter fit a prelude vtec?
Old Nov 29, 2005 | 11:25 AM
24's Avatar
24
Default Does a 92-95 prelude s/si catalytic converter fit a prelude vtec?
like the title says
Old Dec 1, 2005 | 11:36 PM
24's Avatar
24
bump
Old Dec 1, 2005 | 11:43 PM
@ries's Avatar
Default Re: Does a 92-95 prelude s/si catalytic converter fit a prelude vtec? (Lude R)
it will not bolt up.
Old Dec 3, 2005 | 04:19 PM
24's Avatar
24
so only the 93-95 vtec cat will fit?
Old Dec 3, 2005 | 04:47 PM
@ries's Avatar
Default Re: (Lude R)
the 97+ cats share the same design as the 93-96 vtec cat. well, atleast here in california. you can use the 97+ cat but you have to plug the 2nd O2 sensor hole.
Old Dec 4, 2005 | 09:50 AM
ShinobiLude's Avatar
Default Re: (@ries)
I dont know....when I search for cats on ebay...they ONLY sell cats that just says fit for all 92-95 Preludes. Not that they are always right as I well know but I'm pretty sure that the 96 Prelude VTEC cat will be different than the 92-95 because its OBDII. I just think that the 92-95 s/si cats are the same for 92-95 Vtec. Any confirm this?
Old Dec 4, 2005 | 11:51 AM
dohcVTECeg2's Avatar
Default Re: (ShinobiLude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ShinobiLude &raquo;</TD></TR><TR><TD CLASS="quote">I dont know....when I search for cats on ebay...they ONLY sell cats that just says fit for all 92-95 Preludes. Not that they are always right as I well know but I'm pretty sure that the 96 Prelude VTEC cat will be different than the 92-95 because its OBDII. I just think that the 92-95 s/si cats are the same for 92-95 Vtec. Any confirm this? </TD></TR></TABLE>
Old Dec 4, 2005 | 11:54 AM
The Weather Man's Avatar
Man WTF is up with you quoting people................every post of yours is pointless........all you do is quote people.........your posts are being reported.
https://honda-tech.com/zerothread?id=1453023
https://honda-tech.com/zerothread?id=1452709
https://honda-tech.com/zerothread?id=1453042
https://honda-tech.com/zerothread?id=1453101
https://honda-tech.com/zerothread?id=1453157
https://honda-tech.com/zerothread?id=1451370
And thats only a few of them. If you don't have anything to add to these threads, don't post ****. You're such a ***.
Modified by TheKINGPin at 4:54 PM 12/4/2005
Old Dec 4, 2005 | 06:49 PM
prelittlelude's Avatar
hit up http://www.slhondaparts.com and compare the part numbers for the different models, i think that between a si and vtec the are the same but the s is not , confirm by looking up part numbers.
Old Dec 4, 2005 | 07:59 PM
incubus's Avatar
Default Re: Does a 92-95 prelude s/si catalytic converter fit a prelude vtec? (prelittlelude)
IF I remember correctly, they are different lengths. you can make one work if u have a welder. We put a h23 cat on a h22 at my job and we had to make an extension pipe to get it to fit. It could have been that the POS tsudo exhaust the kid brought was just too short, I know it wasnt bent correctly.
Old Dec 4, 2005 | 08:13 PM
Default Re: Does a 92-95 prelude s/si catalytic converter fit a prelude vtec? (incubus)
Well that's cool...my exhaust from the cat back is pretty beast...or i can get my muffler shop to bend and do the pipes for $75. BUT...i bought a megan header...just needed to know if that downpipe went up to my current cat. I'm checking that Honda parts site now...when i was doing this H22A swap...i had no idea that the cat might not work. ****.
Old Dec 5, 2005 | 06:26 AM
shutta's Avatar
from my understanding, h23 cat + exhaust will bolt up to h22 header/downpipe,
you can mix exhaust parts, on an h22 but it can only be h22 header/downpipe with h23 cat and cat-back or all h22 without modding anything
Old Dec 5, 2005 | 06:28 AM
mgags7's Avatar
Default Re: Does a 92-95 prelude s/si catalytic converter fit a prelude vtec? (ShinobiLude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ShinobiLude &raquo;</TD></TR><TR><TD CLASS="quote">Well that's cool...my exhaust from the cat back is pretty beast...or i can get my muffler shop to bend and do the pipes for $75. BUT...i bought a megan header...just needed to know if that downpipe went up to my current cat. I'm checking that Honda parts site now...when i was doing this H22A swap...i had no idea that the cat might not work. ****. </TD></TR></TABLE>
any mass produced header is gonna be the same length as the stock one, or have some provision to reach the cat for you. I think the difference is in the header length....bc i have used an h22 header with an h23 cat and exhaust before without even realizing it.....
Old Dec 5, 2005 | 08:56 PM
24's Avatar
24
ok if i used a cat off a si with my h22 will it pass smog?
Old Dec 6, 2005 | 12:15 AM
@ries's Avatar
i just remembered that the si and vtec cats are only different where the exhaust bolts up to the cat.
the three bolt flange is bigger on the 92-96 vtec cat. so in theory, i believe that the aftermarket "test" pipes will all work since they use bigger flanges anyways. (if you are using an aftermarket exhaust also)
sorry for the confusuion.
mdd
Jan 20, 2008 07:14 PM
bambbrose
Jun 10, 2007 09:14 AM
Ausmith
Jan 23, 2003 04:32 PM
