1988 CRX SI Corner lights stay on
Old Nov 29, 2005 | 10:39 AM
crj_lll's Avatar
Default 1988 CRX SI Corner lights stay on
I am having an issue. The corner lights will not turn off. Any idea what this could be. It already killed one battery. Any help would be appreciated.
Thanks
Old Nov 29, 2005 | 02:17 PM
31flavorscivic's Avatar
Default Re: 1988 CRX SI Corner lights stay on (crj_lll)
Trace the wires find out where they're going? Did you buy the car like that, or did it just happen one day? Could be a bad switch somewhere. I would just make sure they're not hard wired in.
Old Nov 29, 2005 | 02:19 PM
higgunscrx's Avatar
turn your headlight switch off...
Old Nov 29, 2005 | 02:23 PM
Y_my_91's Avatar
i had the same problemwhen i installed a stero in my bros car. it could be the back up fuse under the hood that was my problem
Old Nov 29, 2005 | 05:17 PM
crj_lll's Avatar
Default Re: 1988 CRX SI Corner lights stay on (Y_my_91)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Y_my_91 &raquo;</TD></TR><TR><TD CLASS="quote">i had the same problemwhen i installed a stero in my bros car. it could be the back up fuse under the hood that was my problem
The back up fuse under the hood? What do you mean? Backup for what? Is it a 15 amp fuse? I am missing one of those. Are you saying if I replace that fuse the light will go off?
Old Nov 30, 2005 | 12:23 PM
Y_my_91's Avatar
yes that ****.
Old Nov 30, 2005 | 03:49 PM
dopey88's Avatar
It could also be the parklight relay.
Ralphie
Old Jan 19, 2006 | 02:47 PM
crj_lll's Avatar
Default Re: (dopey88)
Well,
I have check all the appropriate ground wires and the lights are still on. I have noticed that it is only the front parking lights that will stay on. the rear oens turn on and off as they are supposed to. Any suggestions?
Old Jan 19, 2006 | 04:57 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
Default Re: (crj_lll)
direct quote from manual:
Failure modes:
.One or both of the front side marker lights stay on all the time
(ignition and headlights off)
.One or both of the front side marker lights will not illuminate.
If either of these problems exist,replace the side marker relay
(integrated control unit)
Probably &gt;the relay is stuck on...
Old Jan 19, 2006 | 05:34 PM
crj_lll's Avatar
Default Re: (88DXCRX)
YOU ARE THE BOMB. Thanks
Old Jan 19, 2006 | 05:53 PM
88DXCRX's Avatar
here is the control unit:
Located on the backside of the underdash fusebox:
Circuit board inside the box:
I would imagine it is the black square relay
in the upper left corner gone bad..Just a guess though..
Old Jan 19, 2006 | 06:21 PM
rsca_crx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88DXCRX &raquo;</TD></TR><TR><TD CLASS="quote">direct quote from manual:
Failure modes:
Probably &gt;the relay is stuck on...</TD></TR></TABLE>
yessir. i fried mine when i dropped a wrench and it spanned the two terminals on the battery (oops). i unplugged the bulb for a while before running over the solution on accident while thumbing pages.
replacing it solved the problem
Old Jan 20, 2006 | 08:31 AM
crj_lll's Avatar
Default Re: (rsca_crx)
Thanks both of you. You guys are a great help. here s the issue. I have a 1990 Civic Wagonvan. The Wagovan is parking lights work fine. I swaped the relays and still had the same problem.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rsca_crx &raquo;</TD></TR><TR><TD CLASS="quote">
replacing it solved the problem </TD></TR></TABLE>
Rsca_crx, when you replaced the relay, was it the black relay that is located in the upper lefthand corner of the fuse box? When I pulled it and swapped it, it was a 3 prong relay. Any help would be helpful.
Old Jan 20, 2006 | 08:36 AM
crx_88_si's Avatar
unplug one of the lights plugs from the back of the housing. ONE at a time.
if you unplug one and it goes off but the other stays on then the other is the culprit (grounding out somewhere)
Old Jan 20, 2006 | 01:33 PM
crj_lll's Avatar
Default Re: (crx_88_si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx_88_si &raquo;</TD></TR><TR><TD CLASS="quote">unplug one of the lights plugs from the back of the housing. ONE at a time.
if you unplug one and it goes off but the other stays on then the other is the culprit (grounding out somewhere)</TD></TR></TABLE>
Are you talking about the back of th corner light housing? i do not think so as I am sure the light will go out as soon as I unplug the bulb. Help me out with that?
Old Jan 20, 2006 | 04:13 PM
crx_88_si's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crj_lll &raquo;</TD></TR><TR><TD CLASS="quote">
Are you talking about the back of th corner light housing? i do not think so as I am sure the light will go out as soon as I unplug the bulb. Help me out with that?</TD></TR></TABLE>
it would help determine if they are on a common circuit (the ground) and might help you track down which wire to look at for shorting to ground.
use a multimeter to check continuity between the ground pin and chassis as well, can tell u if the gnd has a short in it.
Old Jan 24, 2006 | 04:14 PM
crj_lll's Avatar
UREKA
I finally got the lights to shut off. It was the intergrated control unit. I will let you know what happens when I out it in and if it is truly the fix.
byc_cb7
Sep 28, 2009 02:45 PM
EJ8CIVIC
18
Feb 8, 2008 04:18 AM
-Championship-
Audio / Security / Video
11
Sep 18, 2006 01:18 PM
thresher
Oct 9, 2005 06:56 PM
reallycooleg
Jul 10, 2005 07:20 AM
