Sohc ZC dizzy help!!!
Old Nov 29, 2005 | 10:34 AM
Riceboy891's Avatar
Default Sohc ZC dizzy help!!!
I have an OBD1 NON-VTEC SOHC ZC in my 90 hatch and I am pretty sure the dizzy took a crap on me. I have no idea what to replace it with. The 92-95 1.6's are vtec which wont work. And the non vtecs are all 1.5's which I dont know if that makes a difference. I have also heard of people using an LS dizzy. Any help especially part numbers (td41u, td43, etc.) would be greatly appreciated.
Old Nov 29, 2005 | 10:36 AM
ludesrv's Avatar
I beleive you can use the D16A6 dizzy with ODB1 conversion to it. I am running that setup on OBD0...so I'm not sure.
Old Nov 29, 2005 | 01:15 PM
Riceboy891's Avatar
Default Re: (ludesrv)
anybody know about the ls compatability?
Old Nov 29, 2005 | 01:30 PM
jlicrx's Avatar
Default Re: (Riceboy891)
LS won't fit, but the distributor should be the same as 92-95 D16Z6 from Civic EX
Old Nov 29, 2005 | 01:42 PM
Tyson's Avatar
Default Re: Sohc ZC dizzy help!!! (Riceboy891)
whats the stamp on the one you have now?
Old Nov 29, 2005 | 01:43 PM
daidilus's Avatar
use the distributor for the D15B7 aka the DX engine....will bolt right up
Old Nov 29, 2005 | 02:04 PM
Riceboy891's Avatar
Default Re: (daidilus)
i figured the dx one would work but I just wasnt sure. Oh and by the way there is no stamping on mine, i looked all over for one but no luck.
Old Nov 29, 2005 | 02:06 PM
Tyson's Avatar
did you do an OBD1 conversion? or just saying the engine was from a 92-95 car?
Old Nov 29, 2005 | 02:18 PM
Riceboy891's Avatar
Default Re: (Tyson)
yeah i converted it. It started out as a lowly STD hatch then i dropped a DOHC ZC, then blew that up, then got a SOHC ZC for cheap but didnt realize it was OBD1 till started trying to hook up the o2 sensor and dizzy. So I was like whatever and just got a harness from JKOBD and swapped it over. I had to reverse wire the distributor harness from a DOHC ZC back to a SOHC one. (external to internal cam sensor)
Old Nov 29, 2005 | 02:24 PM
Tyson's Avatar
yeah, just checking.
reverting it back to non OBD is a possibility.
but id look into that DX distributor. i dont see why that wouldnt be compatible. but i dont know much anyway
Old Nov 29, 2005 | 02:33 PM
Riceboy891's Avatar
Default Re: (Tyson)
Thanx for the help guys. My friend let me borrow his ls dizzy so Im gonna be tryin that in the morning and if that doesnt work ill prolly be hittin up Distributor king for a dx dizzy. Ill let ya know how it goes.
Old Nov 29, 2005 | 04:36 PM
esteen2's Avatar
the td41u should work fine.
Old Nov 21, 2019 | 04:44 PM
Lee Palmer's Avatar
Default Re: (Tyson)
Did it work?
Canadian_EF
10
Aug 26, 2009 06:52 AM
andrewtp
Mar 20, 2009 03:48 AM
Unique Artwerkz
Sep 30, 2007 06:20 AM
crxsleeper210
Jan 8, 2007 09:01 AM
arc_55
Jul 1, 2006 09:40 AM
