Extended wheel stud locks?
I'm looking for some rim locks for my extended wheel studs, not the kind you buy at AutoZone; those are too short. Can anyone point me in the right direction? Save me from the thieving Los Angelinos in my neighborhood!
bulldog I think makes some, i have some around here somewhere. only problem is you have to bore a 14mm hole through the key since it is not long enough to fit over the stud
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LudeToAHatch »</TD></TR><TR><TD CLASS="quote">I'll check those out.. Anyone know of any that have an extended socket/key?</TD></TR></TABLE>
i researched this for a couple of months last year, I looked in every wheel stud/nut/lock catalog that is available at tire stores, aftermarket shops, etc..
unless something new came out, there is really no "uniquely" keyed open ended locks with a socket that will fit over the long studs without modification
gakkuken
21
Jan 10, 2005 02:28 PM
Seedc2
Jun 11, 2003 06:20 PM
