car wont start...help anyone
Old Nov 29, 2005 | 09:35 AM
CNSK's Avatar
Default car wont start...help anyone
my car wont start anymore....dont know why.....it cranks but the motor wont run...it doesnt throw any code.....when i mess the engine wire harness down at the ecu plugs, I can hear this clicking noise...sounds like a relay or fualty wire but how do i know if one of my wire is short or the relay is bad? I check my injector wires and still intact well, my rc injectors are new, new fuel filter, fuel pump still pumps when i turn the ignition on, timing belt is set correctly, check the fuses inside and underneath the hood........im confused...any input will help.....
its obd2-obd1 if that helps......
my hondata still powers ups.....I drove it one weekend...parked it and next day when i try to crank it...wont power up anymore....
Old Nov 29, 2005 | 09:55 AM
98 Spec R's Avatar
Default Re: car wont start...help anyone (CNSK)
Check the Main Relay for the Fuel Pump under the drivers side dash. If that is clicking it is probably bad. I have seen this Relay go bad on a few Integras and Civics.
Old Nov 29, 2005 | 01:36 PM
GSRacer1's Avatar
try to hook up the obd2 ecu again, maybe the ecu conversion harness is messing up.
Old Nov 30, 2005 | 04:25 AM
CNSK's Avatar
Default Re: car wont start...help anyone (GSRacer1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSRacer1 &raquo;</TD></TR><TR><TD CLASS="quote">try to hook up the obd2 ecu again, maybe the ecu conversion harness is messing up.
tried it...wont start....ill check the relay though....a picture of the relay can help if somone has it...
Old Nov 30, 2005 | 04:48 AM
CNSK's Avatar
how do you check and see if a relay is bad?
Old Nov 30, 2005 | 05:05 AM
M Coop's Avatar
Swap it out with another one of course.
Old Nov 30, 2005 | 10:05 AM
b20vtecpimp's Avatar
Default Re: car wont start...help anyone (M Coop)
if your main relay is bad then that often cause u to get spark but no fuel.check all grounds, check for spark
Old Nov 30, 2005 | 10:16 AM
you could also check your fuel by taking off the 17mm fuel line going to the fuel filter from the firewall,then turn the key to see if fuel is being pumped.(be ready to cut off the ignition due to fuel-sray),
Old Nov 30, 2005 | 11:41 AM
MRCHUNDOESAY's Avatar
ECU
Old Nov 30, 2005 | 11:50 AM
CNSK's Avatar
Default Re: car wont start...help anyone (b20vtecpimp)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b20vtecpimp &raquo;</TD></TR><TR><TD CLASS="quote">you could also check your fuel by taking off the 17mm fuel line going to the fuel filter from the firewall,then turn the key to see if fuel is being pumped.(be ready to cut off the ignition due to fuel-sray), </TD></TR></TABLE>
did that already....fuel sprays out from the fuel filter so i know im getting fuel, i checked my spark plug wire so see if im getting sparked and it has sparks.....im about to give up.....ive thought of every possible solution...i honestly think its faulty wire from my wire harness becuase when I move it around i can hear this clicking noise .....could be bad relay but damn which one???? and how do I know its bad?
Old Dec 1, 2005 | 09:19 AM
CNSK's Avatar
ttt
Old Dec 3, 2005 | 11:12 AM
GSRacer1's Avatar
try to swap out the relay's. you can get one from the junk yard for like a dollar or something.
Old Dec 3, 2005 | 11:27 AM
CNSK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSRacer1 &raquo;</TD></TR><TR><TD CLASS="quote">try to swap out the relay's. you can get one from the junk yard for like a dollar or something. </TD></TR></TABLE>
which one though? there so many.......and how do i know if its bad...thats my question....
Old Dec 3, 2005 | 01:36 PM
M Coop's Avatar
If you have a book check out the wiring diagrams and by process of elimination you can probably narrow it down to a couple of them, then you just swap the ones that are suspect with others that match. Are you sure the ECU is OK?
Old Dec 3, 2005 | 05:33 PM
Lifted's Avatar
In my own opinion, if you have the stock ECU, I'd toss that in just to see if that's the problem. Might even try having a friend move the harness around while I try turning it over just to eliminate that thought. For a buck each, I'd grab as many relays in there as you can and go through process of elimination. Sorry, know it's not the best advice, but it's what I'd do even though it's probablly not right.
Old Dec 4, 2005 | 05:16 PM
CNSK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by M Coop &raquo;</TD></TR><TR><TD CLASS="quote">If you have a book check out the wiring diagrams and by process of elimination you can probably narrow it down to a couple of them, then you just swap the ones that are suspect with others that match. Are you sure the ECU is OK?</TD></TR></TABLE>
yes i did swap out the ecu for my other stock p72 ecu and still nothing. Ill figure it out eventually....
Old Dec 5, 2005 | 01:07 AM
23snorub's Avatar
try seeing how much fuel pressure u gettin
here is what i have for sale
digital audio amp 300 watts
http://i24.photobucket.com/alb...5.jpg
fusion alarm
http://i24.photobucket.com/alb...n.jpg
rc injectors 440 like new!!!!
http://i24.photobucket.com/alb...s.jpg
Modified by 23snorub at 3:29 AM 12/9/2005
Modified by 23snorub at 3:39 AM 12/9/2005
Old Dec 5, 2005 | 04:12 AM
M Coop's Avatar
How about the coil? Are you absolutely sure you're getting spark? Had a friend that couldn't get his car started over the weekend, ended up being a bad coil.
Old Dec 5, 2005 | 04:40 AM
CNSK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by M Coop &raquo;</TD></TR><TR><TD CLASS="quote">How about the coil? Are you absolutely sure you're getting spark? Had a friend that couldn't get his car started over the weekend, ended up being a bad coil. </TD></TR></TABLE>
are you talking about the distributer? ill check and see.....
Old Dec 5, 2005 | 10:15 AM
ITB
Guest
Posts: n/a
check your starter and ignition
Old Dec 5, 2005 | 10:20 AM
M Coop's Avatar
Yea I think the stock coil is in the distributor. Right?
Old Dec 5, 2005 | 10:29 AM
CNSK's Avatar
ill look into it...but i dont think its mechanical...i think its something electrical...
Old Dec 5, 2005 | 10:50 AM
brolli's Avatar
do your injectors have pulse width? your car needs three things to run, air, fuel, and spark. air=check compression. fuel=check pressure and injector pulse. spark=check spark. process of elimination.
Old Dec 6, 2005 | 04:19 AM
M Coop's Avatar
Well yea that's what I mean, I don't think you're getting spark. Have you tested it to try to find out if you're getting spark? If you take one boot off the plug you should be able to put it next to the valve cover and have someone crank on the car, if you see spark jumping on the valve cover you have spark.
Old Dec 6, 2005 | 05:50 AM
jDm_jeremy's Avatar
i think main relay also
