how to wire an MSD RPM activation switch
Old Nov 29, 2005 | 08:15 AM
blkhatch92's Avatar
Default how to wire an MSD RPM activation switch
i got a 89 crx with an d16a6/z6 minime and i need to know how to wire an rpm activation switch for vtec ?? pics would work nicely if u got any thx
Old Nov 29, 2005 | 08:32 AM
sanimalp's Avatar
$cat /dev/urandom
Default Re: how to wire an MSD RPM activation switch (blkhatch92)
wait, but if you use a switch, how do you get the extra fuel to your engine that vtec engagement will need?
you should get a vtec ecu or buy a converted chipped vtec ecu. much safer, and youll get better performance.
Old Nov 29, 2005 | 09:31 AM
blkhatch92's Avatar
rpm switch will do the same thing as the vtec ecu, it just wont feed the extra fuel, whitch isnt very much at all, i wont get the best performance from the switch, but its better than what i have now.
Old Nov 29, 2005 | 09:59 AM
crxnj's Avatar
Default Re: (blkhatch92)
If it doesnt give the extra fuel then that means the motor will run lean in vtec..You can blow your **** up doing that..But whatever..
You need a 30amp realy so you dont blow out the vtec solenoid,,
http://x1000.putfile.com/videos/d4-32701451986.mov
Modified by Mr.speaker at 10:42 AM 12/2/2005
Old Nov 29, 2005 | 10:24 AM
blkhatch92's Avatar
Default Re: (Mr.speaker)
thx alot lol im running my car retarded timing which gives it more fuel so therefor it will run rich when vtec isent kicked in (which willll not hurt nothing but the spark plugs)and when it does kick in then ya no VVVVTTTEEEECCCCCC!!!
Old Nov 29, 2005 | 11:04 AM
blkhatch92's Avatar
where does the wires on the vtec solinoid go cause there is only one being used which is the green and there is two left so can someone help me out??
civicjoe
16
Feb 25, 2008 01:57 PM
philkehn
10
Oct 3, 2006 11:55 AM
mycvc8u2
Jun 14, 2003 06:29 PM
eg6madness
Mar 5, 2003 07:52 AM
project dc2
Dec 24, 2002 06:49 AM
