Hesitation ????
Old Nov 29, 2005 | 06:30 AM
lude98SH's Avatar
Default Hesitation ????
Today i was driving and it feels like my car is hesitating and losing all power at around 3k and then stops but still feels weak through the rest of the rpm range. This just started yesterday. The car was warm, plugs, wires, distristbuter cap and rotor were all changed within the last 1000 miles. Car has 119k on it. Is not abused but not babied either. No check engine lights. Oil was changed less than 1000 miles ago. Vtec did engage but felt weak.
Old Nov 29, 2005 | 06:41 AM
Silver Surfer's Avatar
ignitor might be starting to go.....you can get a whole distributor for close to what the ignitor costs.....and it only takes 5-10 mins to install a distributor....at least it did on my 95vtec
Old Nov 29, 2005 | 06:48 AM
lude98SH's Avatar
Default Re: (Silver Surfer)
The whole distributer or the coil ? Or both ?
Old Nov 29, 2005 | 08:53 AM
Fly1865's Avatar
Default Re: (lude98SH)
Knock Sensor
Old Nov 29, 2005 | 01:01 PM
with mine there was hesitation in low rpms and very high like 6500+.......it eventually died on me and i took it to honda....they said it was the ignitor......i replaced the whole distributor....not the coil which is external
Old Nov 29, 2005 | 03:57 PM
lude98SH's Avatar
Would a 4th gen h22 distributor fit?
Old Nov 29, 2005 | 07:50 PM
Fly1865's Avatar
If you are OBDI you have use an H23 or H22 dizzy, but if you are OBDII you need a 97+ dizzy. If you have a 96 you were one of the lucky ones that have to buy alot of stuff.
Not to jack up the threat, but i have an OBDII dizzy for sale, i bought it new and only used for 2k, 75 shipped.
Old Dec 3, 2005 | 12:06 PM
lude98SH's Avatar
Default Re: (Fly1865)
So do u guys think its the knock sensor or the ignitor ?
Old Dec 3, 2005 | 12:24 PM
ckyskater733's Avatar
mine is sluggish around 3k but goes away at around 4k....i pulled a code for the egr valve. i havent gotten around to fixing it though.
Old Dec 3, 2005 | 12:37 PM
lude98SH's Avatar
Default Re: (ckyskater733)
Thanks I'll have to check tht out. The egr valve would usually just involve cleaning it out, correct ?
Old Dec 4, 2005 | 07:10 AM
lude98SH's Avatar
bump
Old Dec 11, 2005 | 05:32 PM
lude98SH's Avatar
bump
hb_guy
Mar 23, 2011 11:16 AM
erik92DA
Jun 8, 2006 08:16 PM
flight50
Apr 3, 2006 07:32 AM
2000Pimpinex
Jan 31, 2006 05:50 AM
ophdehEEzY
Mar 8, 2003 10:06 PM
