my ecu is throwing cods 1 2 17 and 23
Old Nov 28, 2005 | 08:15 PM
ppl talk bout my old name's Avatar
Default my ecu is throwing cods 1 2 17 and 23
1 and 2 are o2 sensors how do i fix 17 is vss but i still hit vtec how do i fix and 23 is knock sensor how do i fix any help would be super nice im scared to drive it will it hurt any thing
Old Nov 28, 2005 | 11:25 PM
DieMaster's Avatar
Needs to be About 20% Cooler
Default Re: my ecu is throwing cods 1 2 17 and 23 (ten second crx)
17 and 23 wont hurt anything unless your motor is pinging. 17 is in your dash. gauge cluster spedomiter. if u take out the gauge cluster directly below the speed cable are 2 screws. thats the VSS. so theres a open between there and the ecu. 23 is knock sensor. i'm assuming your running a pw0 or pr3. knock is not nessary and u could ground the wire for it but as i'm oem freaky, i'd put one in.
Old Nov 29, 2005 | 11:05 AM
jdmcars.com's Avatar
code 17: is your speedo even working? (cable installed back into place, speed sensor hooked up)?
Code 23: Is your knock sensor wired up? Pin is B19 for knock on ECU.
Old Nov 29, 2005 | 05:37 PM
Default Re: my ecu is throwing cods 1 2 17 and 23 (jdmcars.com)
thanks man
1320king
10
Sep 23, 2007 06:36 PM
ek4 sir civic
Jun 28, 2007 07:09 PM
acclude-vtec
Jan 2, 2006 11:00 AM
ninkei
Nov 15, 2005 04:45 PM
tc_gts
11
May 4, 2005 05:26 AM
