Buzzing noise coming from tranny after clutch install
Old Nov 28, 2005 | 08:06 PM
Junkyard2000's Avatar
Default Buzzing noise coming from tranny after clutch install
I finally had my exedy clutch/fidanza flywheel installed, but ever since, I hear a low whining noise at low speeds and the faster i go, the louder the noise becomes and it has a buzzing sound, especially at freeway speeds. It gets the loudest when im going fast in 5th gear and i let go of the gas. The noise goes away if I press the clutch.
The onyl thing that was replaced was the clutch, flywheel, throwout bearing(came with the clutch). So i doubt its any of the bearings inside the tranny. Also went from 10-30 oil to 5-30.
Any idea on how to fix this? better tranny fluid? maybe the exedy bearing was bad? Can i just use my old one?
Old Nov 28, 2005 | 08:09 PM
silentdork818's Avatar
Default Re: Buzzing noise coming from tranny after clutch install (Junkyard2000)
Damn 5w30? Honda recommends at least 10w30, and 10w40 for hotter climates. I would think its that...
Old Nov 28, 2005 | 08:12 PM
krazie1's Avatar
BANNED
Default Re: Buzzing noise coming from tranny after clutch install (ef four door)
the oil ain't the problem
it has to do with the clutch or pressure plate I bet my car on it, seems u could of damaged the teeth on the pressure plate which is causing so scratching against the clutch and it is spinning or something like that is occuring which causing this whinning noise as u are going into higher rpm's or speeds
Old Nov 28, 2005 | 08:16 PM
Default Re: Buzzing noise coming from tranny after clutch install (krazie1)
clutch was brand new. Im gonna maybe try some syncromesh but i doubt thicker fluid is gonna get rid of it. Anyone else?
Old Nov 28, 2005 | 09:27 PM
31flavorscivic's Avatar
It sounds like a throwout bearing thing, but since you replaced it I have no idea.
Old Nov 28, 2005 | 09:31 PM
Default Re: Buzzing noise coming from tranny after clutch install (31flavorscivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 31flavorscivic &raquo;</TD></TR><TR><TD CLASS="quote">It sounds like a throwout bearing thing, but since you replaced it I have no idea.</TD></TR></TABLE>
i replaced my old one with the new one that came with the clutch. Before the install there wasnt any noise.
Old Dec 8, 2005 | 07:11 PM
fastnlow93teg's Avatar
my car is doing the same thing..i put in a new clutch today-bearing and all. and it still does it..i even put royal purple in the tranny..noise stops when clutch is engaged..i have no idea-im boggled
Old Dec 8, 2005 | 07:53 PM
EG8R's Avatar
Default Re: (fastnlow93teg)
Generally replacing the release bearing gets rid of that noise...
Old Dec 8, 2005 | 11:55 PM
1QuikSOHCZC's Avatar
Default Re: (skelly ed666)
i did the same...brand new clutch install in my tranny.....the input shaft bearing in the tranny is goin out on mine....so maybe thats everyones problem....u could replace it or jus get a another tranny like me.......makes same noise, gets louder as my rpm's go higher....and mine is really loud at a cold start, and when it warms up good the noise isnt as Bad..
Old Dec 9, 2005 | 12:43 AM
Tyson's Avatar
im no tranny expert, but it sounds like the input shaft bearing is going.
could have happened if you manhandled the tranny in and out, resting the tranny on the input shaft alone, barely in.
https://honda-tech.com/zerothread?id=596873
btw, i really recommend you use Honda MTF, not regular engine oil. GM synchromesh or whatever equivelent i hear is good too.
Old Dec 20, 2005 | 10:28 AM
Default Re: Buzzing noise coming from tranny after clutch install (Tyson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson &raquo;</TD></TR><TR><TD CLASS="quote">im no tranny expert, but it sounds like the input shaft bearing is going.
btw, i really recommend you use Honda MTF, not regular engine oil. GM synchromesh or whatever equivelent i hear is good too.</TD></TR></TABLE>
its gonna suck if i take the tranny out and replace the input shaft bearing, only to realize the problem was the throwout. I hate this tranny **** im gonna buy a new one
Old Dec 20, 2005 | 11:51 AM
Jerms's Avatar
yah the input shaft bearing is goin
lurkin' eg
Jun 8, 2008 08:17 PM
NonovUrbizniz
21
May 2, 2005 05:39 PM
Andrew 825SM
Nov 21, 2003 12:46 PM
garados
Dec 20, 2002 03:17 PM
RacerMike
Jul 22, 2002 07:26 AM
