Checking Cell 4th Gen
Old Nov 28, 2005 | 07:57 PM
96lude_srv's Avatar
Default Checking Cel 4th Gen
i tried doing a diagnostic test and ecountered some problems.
On here http://www.92lude.com/diagnose_error_codes.htm, when i located the blue connector there are 4 pins and i dunno which one to ground out. Should i ground out the 2 wires that run into the 2 pins?
I notice there's a strong gas fume, positive that it's due to the o2 failing and causing the car to run really rich. I was able to attain 138km from half a tank until the gas light came on. So there wasn't any point in running 91octane when she's just going to run really rich. i decided to run regular and my gas mileage improved big time. i can squeeze out 250km to half a tank.
Before all this happened and running on premium , i was only able to squeeze out about 200km to half a tank..
i appreciate any comments.
Thanks
Old Nov 29, 2005 | 05:50 AM
The Weather Man's Avatar
Get a real a/f gauge........and see the reading.
I know a lot of people won't agree with me here - but If the o2 is failing, and its making the car run rich - keep using the cheap gas. As long as the car isn't running pig rich - what the hell. they run rich from the factory. Now, if you're in an area that has emissions, sorry for ya. Get a new o2 sensor and start using 91 octane again.
Old Nov 29, 2005 | 08:27 AM
96lude_srv's Avatar
Default Re: (TheKingPin)
I notice the gas fume went away when i started using cheap gas. I'll be saving up for both o2 sensors and a hi-flow cat. I won't have to worry about emission for another 1.5years
gtimax
Aug 17, 2011 10:53 PM
91crxturbo
May 7, 2008 02:13 PM
dc4g
Nov 28, 2005 08:30 AM
quik sol
Aug 14, 2004 09:12 AM
EGfastback22R
Feb 10, 2004 10:53 AM
