sleavsed motors
Old Nov 28, 2005 | 07:51 PM
pandadx's Avatar
Default sleavsed motors
ok i just bough b16a for my 1990 civic dx. i have pulled the block apart and had the head work a little with new spings and retanner. now i am putting new piston and when i went to clean the top of the block the cylinder wall was like a different metal because around the cylinders is a place where the coolant flowes. that seem to be aluminum but the cylinder is different. if this is normal please let me know. this is my first Honda i have work on.
Old Nov 28, 2005 | 08:14 PM
HiProfile's Avatar
Default Re: sleavsed motors (pandadx)
Stop everything you're doing. Go buy a helms manual for a honda that had a B16 or B18 vtec motor as an option. Then procede to reassemble the motor...properly.
Stock honda motors are open deck, meaning the cylinders aren't connected to the rest of the deck. They come stock with iron sleeves pressed into the coolant sleeves, which are part of the block casting. Meaning, yes, it's how it should be. You'll have roughly half the top of the sleeve a dark iron, and the rest/outter part a whitish aluminum.
Old Nov 28, 2005 | 08:24 PM
vw eater's Avatar
what book would u get for a jdm b16a first gen? a honda del sol book?
Old Nov 28, 2005 | 08:33 PM
pandadx's Avatar
Default Re: sleavsed motors (HiProfile)
what is the max boost that i could run. i have 9:5 to 1 pistons and new rods
Old Nov 28, 2005 | 08:37 PM
boylovecar's Avatar
new honda rods or aftermarket?
Old Nov 28, 2005 | 08:39 PM
pandadx's Avatar
Default Re: sleavsed motors (boylovecar)
after market
Rs25GT
Welding / Fabrication
18
Apr 7, 2010 06:29 AM
foca
May 12, 2008 12:16 PM
VisualAutoMotoring
Jan 6, 2004 02:25 PM
ppihctyper
May 14, 2002 05:45 PM
