obd2b distributor on obd2a engine
Old Nov 28, 2005 | 05:05 PM
4dooreg-k's Avatar
Default obd2b distributor on obd2a engine
just wondering if i can take the guts of a d16y8(obd2b) distributor and put them in a jdm b16a (obd2a) distributor. cause im using the obd2b harness on the b16 and i noticed the plugs for the distributor are different. the obd2a has 2 extra wires.
Old Nov 28, 2005 | 06:17 PM
hondaguyef's Avatar
Default Re: obd2b distributor on obd2a engine (4dooreg-k)
I believe the only interchangeable piece is the ICM. Everyhitng else is different.
Phil
Old Nov 29, 2005 | 09:39 PM
RPM Partz's Avatar
Default Re: obd2b distributor on obd2a engine (hondaguyef)
Im not sure which distributor you are taking the guts out of, but if you can give me the TD# off your dizzzy I can help you. Your probably using a TD84U, But let me know. I work for a company that makes / sells JDM dizzies...Mike
