sh tranny in a h22a1
Tranny does bolt up, don't know about the SH part of it. It's outside and behind the motor....I would assume so, but why do that when you can get JDM LSD H22A trannies.
it will require the ATTS unit, and ATTS specifical axles. there is no gain to using nay of tha tunless you really want an extra 90 lbs of weight on the back of the engine that will not bolt up without a custom bracket, plus it wont clear the oil filter either.
you will need to make custom brackets for the atts, halfshafts, and all kinds of other little **** wont work.....
shortly, no, but the internals should all work, with the exception of the differential....
