Headlight change bulbs !!
Old Nov 28, 2005 | 03:40 PM
Elbowpunk's Avatar
Default Headlight change bulbs !!
How do u change the bulbs on my 91 Teg LS
Thanks...
Old Nov 28, 2005 | 04:22 PM
Elbowpunk's Avatar
Default Re: Headlight change bulbs !! (Elbowpunk)
UP UP UP ...
I NEED HELP ... I dont kno how to do it...and need to do it right now plz...
Thanks
Old Nov 28, 2005 | 04:28 PM
Rajin's Avatar
Conversion or just routine bulb change?
Old Nov 28, 2005 | 04:42 PM
Elbowpunk's Avatar
Default Re: Headlight change bulbs !! (Rajin)
routine .... i jsut got brighter bulbs cuz my other ones were gettin old...being in there for years !!
Old Nov 28, 2005 | 05:20 PM
Wayne_Curr's Avatar
unplug the harness, twist the bulb, pull it out, attach the harness to the new bulb, put back in hole, twist to lock into place. Simple. dont touch the glass on the new bulbs though, dont want to get any skin oil on um.
Old Nov 28, 2005 | 05:23 PM
ninhers's Avatar
First unplug the 3 wire harness in the bulb.
If there is a rubber boot, remove this next.
Then twist off the plastic ring that holds the bulb in place
(should be maybe an 1/8th to a 1/4 turn counter clock wise)
To put back in, reverse the procedure.
Old Nov 28, 2005 | 07:45 PM
Elbowpunk's Avatar
Default Re: Headlight change bulbs !! (ninhers)
SICK !! Thx guys... SO MUCH BRIGHTER !! HAHAH
thecrackerjack
Lighting
Sep 9, 2007 05:38 PM
LudeChild
Mar 26, 2005 09:58 AM
EGcivicBoy
12
Apr 2, 2004 03:48 PM
KCLude01
Nov 11, 2003 06:10 PM
mr_mbuna
Sep 14, 2002 06:53 PM
