Honda Dual-Core Radiator?
Old Mar 13, 2002 | 11:31 AM
Stop the Beast's Avatar
Default Honda Dual-Core Radiator?
On Hybrid Honda their is an article stating that a 96+ Civic EX 4-Door w/automatic has a beefier dual-core radiator. How can you tell how many cores it has. Has anyone seen this in person. I want to know cause it's hot as hell in AZ and I want a bigger radiator with my B18 swap into my '97 CX. Thanks
Old Mar 13, 2002 | 11:35 AM
Katman's Avatar
Default Re: Honda Dual-Core Radiator? (brokstar)
telling dual and single core radiators apart is easy.
Just look at the side of your current radiator, and see if the its approx. 1/2 inch thick...if it is, then you have a single core. Dual core is just that....dual cores...so 2 x 1/2 = 1". A dual core radiator would be approx. 1" thick in width (it could be a little over 1", that's why I abbreviate 'approximately')...
Old Mar 13, 2002 | 11:38 AM
Spade's Avatar
When you look at it from above (in the car) it will look like they took the A/C condenser and put it behind the radiator......basically two radiators one in front of the other stacked.
IsiahCKL
10
Aug 23, 2013 10:26 PM
cpforyou
May 13, 2005 05:44 PM
Stop the Beast
12
Mar 14, 2002 12:19 PM
