i want to lower my car and i need help
ok so i want to lower my car before i get new rims but i have no clue what brand springs and stuff to get and how low i should go cause i really don't want to rub or scrape cause the rims i want are 17x7. If anyone can help me that would be great
I have 17X7 rims on my CRX and I love it! I also have the coilovers! I would recommend them cause they are adjustable to your needs. You can get a set for cheap(cheap being 200 bucks) but remember you get what you pay for! Also make sure you ride with your axles straight or as straight as possible. You will start going through U-joints if the car is to low because your axles are spinning at a bad angle!! I have to replace mine cause I thought it would be cool to be low! One more thing make sure the rear of the car is just a couple of millimeters higher than the front. Its helps your rear follow the front in cornering.
brivnle
Suspension & Brakes
13
Nov 30, 2015 08:09 PM
ottomatic
Suspension & Brakes
17
Feb 24, 2008 02:52 PM
mushu315
18
Jul 18, 2004 01:16 PM
