Omnipower sports not low enough?
Old Nov 28, 2005 | 02:32 PM
carlton585's Avatar
Default Omnipower sports not low enough?
On my EJ8, I believe, when I initially installed them, that I set the front shock bottoms as low as they would go, and the rears as low as they would go. The rears went down far enough to tuck wheel on 205/40/16s and the fronts still leave 1-2 fingers of gap. Its ridiculous. So I had to raise up the rear shock sleeves to even it out.
Are all of the Omni's like this? I searched and found another person with this problem. But that was all. Yes, I preloaded the springs, and didnt touch the spring perch (like it said) and no, there is no problem with my control arm hitting the fender wells.
Before: (You can kinda tell the gap between the pics from the front in relation to the rear)
After: (After I raised up the rear)
You mean to tell me that that is the LOWEST I can go on a 205/40/16? Seems to me that there is something wrong with my coilover setup from Omni. That is not 4" of adjustment.
Old Nov 28, 2005 | 02:36 PM
B18ls*RAYON's Avatar
Default Re: Omnipower sports not low enough? (carlton585)
That sucks man!
Old Nov 28, 2005 | 02:42 PM
Fook_me_honda's Avatar
Default Re: Omnipower sports not low enough? (B18ls)
i think it looks good, sort of like a functional drop
Old Nov 28, 2005 | 02:43 PM
jdm civic 2000's Avatar
4" of adjustment is threw the whole setup not just the bottom....your lucky to get 2" from the bottom.
Tad's Avatar
Tad
Can u jack up ur car and show us a pic of the coilovers as they are right now?
maybe you can just drop the springperch some.
There should be more drop to be had there.
However any ammount you drop it at the springperch, will decrease your supsension stroke that much.
Now this is actually not a big deal, because if you are going to drive around that low you do not want to have all the stroke in the world,
what'll happen is when you hit a bump in the road or something, you're tires and/or suspension components will rub on your inner fender.
Old Nov 28, 2005 | 02:52 PM
VRD^sam's Avatar
Default Re: (Tad)
Are you sure how come my bro's car was so low...
Old Nov 28, 2005 | 02:53 PM
ekcivic9's Avatar
maybe give a little time for it to settle?
EJAYSICKS's Avatar
Default Re: (jdm_madman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tad &raquo;</TD></TR><TR><TD CLASS="quote">
Can u jack up ur car and show us a pic of the coilovers as they are right now?</TD></TR></TABLE>
Do It!
Old Nov 28, 2005 | 03:01 PM
Default Re: (EJAYSICKS)
heres a picture of my car w/ the omnipower sport setup.i have the bottom as far down as possible and i dropped the spring perch some too.. i dont like it to low so this is how i sit. i said the same thing with only dropping the bottoms on all 4 corners..but i had to sacrifice some stroke to..but not a whole lot. idk try playing with the spring setting.
Old Nov 28, 2005 | 03:02 PM
Shmolie's Avatar
I have a 97 coupe with omni and i had the same problem i just lowered it with the springs ride isn't that much diffrent but i am sure the struts aren't going to last as long. i say slam it
Old Nov 28, 2005 | 03:03 PM
unknown0001's Avatar
Default Re: (Shmolie)
Old Nov 28, 2005 | 03:12 PM
Built to Spill's Avatar
el diablo
the drop looks fine to me. Eh, i never really got into the "slammed" look.
Old Nov 28, 2005 | 03:26 PM
R81_DC2's Avatar
https://honda-tech.com/zerothread?id=1441385
this car has omni's , and its slammed. (sorry to the owner for not asking)
Old Nov 28, 2005 | 03:34 PM
JDM_Risa's Avatar
Default Re: Omnipower sports not low enough? (jdm civic 2000)
you can lower the omni's more by spinning the lower half but you will scrafice some of the ride smooth/stiffness
Old Nov 28, 2005 | 03:35 PM
crxmadman's Avatar
Default Re: Omnipower sports not low enough? (JDM_Risa)
i've seen someone with omni's and custom spring rates..would that help the drop a bit?
Old Nov 28, 2005 | 03:38 PM
Mugen112's Avatar
yes, take a few pictures of the setup.
Old Nov 28, 2005 | 03:47 PM
.water's Avatar
since spring rate is stiff, you dont need much shock travel. so lower ur coils.
but that drop looks good to me.
Old Nov 28, 2005 | 04:00 PM
ZacCarter's Avatar
You didnt preload, read the directions, you adjust the sleeve itself not the perches.
Old Nov 28, 2005 | 04:25 PM
DangerMouse's Avatar
shouldn't this be in suspension?
Old Nov 28, 2005 | 04:53 PM
Reza^'s Avatar
Default Re: (Turbo_D)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo_D &raquo;</TD></TR><TR><TD CLASS="quote">shouldn't this be in suspension?</TD></TR></TABLE>
give him a break man , he's a big ol dummy~
Old Nov 28, 2005 | 04:56 PM
ZacCarter's Avatar
Default Re: (reza")
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by reza" &raquo;</TD></TR><TR><TD CLASS="quote">thats what happens when you buy cheap *** suspension ..
welfare must be a bitch.</TD></TR></TABLE>
Sorry we can't afford what you can.
Old Nov 28, 2005 | 04:59 PM
ZacCarter's Avatar
Hmmm, I do save, for thing that appreciate in value like a house or a Ferrari not some beat *** honda.
Old Nov 28, 2005 | 05:13 PM
life sux die's Avatar
RIP 1032
Default Re: (reza")
carlton likes to talk **** , hey I can't do the same?</TD></TR></TABLE>
"If you kiss me then I'll kiss you back
Yea, Kiss me and I'll kiss you back
You with it? 'cause if you with it, I'm with it, yo
Yea, mmm-
Just kiss me then I'll kiss you back
I'll kiss you back, I'll kiss you back"
-Digital Underground
Old Nov 28, 2005 | 05:14 PM
el diablo
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by reza" &raquo;</TD></TR><TR><TD CLASS="quote">why are you pm'ing me , im not a homosexual like yourself.</TD></TR></TABLE>
hahahahah
*thud
Old Nov 28, 2005 | 05:24 PM
v0lcom27's Avatar
Default Re: (GullyFromJerz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GullyFromJerz &raquo;</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zerothread?id=1441385
this car has omni's , and its slammed. (sorry to the owner for not asking)</TD></TR></TABLE>
