H&R Race Springs vs Tanabe Super Down Precedeo for 94-01 integra
Old Nov 28, 2005 | 11:40 AM
tkycgo's Avatar
Default H&R Race Springs vs Tanabe Super Down Precedeo for 94-01 integra
Which is better for lowering my integra?
Old Nov 29, 2005 | 06:16 AM
tkycgo's Avatar
Default Re: H&R Race Springs vs Tanabe Super Down Precedeo for 94-01 integra (tkycgo)
Old Nov 29, 2005 | 07:35 AM
Kendall's Avatar
Well, you need to figure out how low you want it, what spring rates you want, and what shocks you're going to use, then research the exact drop for each set and what rates they have available and make an educated decision for yourself once you have all of that information.
-Kendall, master of run-on sentences
Old Nov 29, 2005 | 11:23 AM
ALLSPRINGS.COM's Avatar
H&R Race springs require aftermarket shocks too....
Old Nov 30, 2005 | 12:35 AM
tkycgo's Avatar
Default Re: (Kendall)
well, I have oem shocks only....... now I have installed weapon r adj. coilovers.... but I am not sure how to make them balance height. That's why I want to change to lowering springs.
If I use oem shocks, which (H&R-germany, Tanabe-japan) is better quality?
Old Nov 30, 2005 | 06:00 AM
Danronian's Avatar
There probably is not "better." Only some people prefer one spring, and others prefer another. I'd just recommend saving for some koni yellows for the coilovers you have now. Balancing the height is super-easy, just measure from the bottom of the sleeve to the adjuster and adjust the same for both side. Done. And then you can pick your height w/o being stuck with what spring company sells you.
Old Nov 30, 2005 | 06:31 AM
Kendall's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Danronian &raquo;</TD></TR><TR><TD CLASS="quote">Balancing the height is super-easy, just measure from the bottom of the sleeve to the adjuster and adjust the same for both side. Done.</TD></TR></TABLE>
Or you could have the setup cornerweighted.
denracho
Suspension & Brakes
Jan 19, 2010 11:08 AM
AntMan401
Suspension & Brakes
20
Aug 18, 2006 09:59 PM
dom5372
Suspension & Brakes
Nov 16, 2005 11:44 AM
The G2 Racer
10
Mar 17, 2003 08:53 AM
garados
Jan 23, 2002 09:32 AM
