Any Difference between JDM and USDM injectors (OBD-1 for VTEC)
Old Nov 28, 2005 | 11:13 AM
NoVALude's Avatar
Default Any Difference between JDM and USDM injectors (OBD-1 for VTEC)
Not sure if I searched under the right criteria, but could not find anything related to JDM vs. USDM injectors. I have an H23 and will be swapping in an H22A4, so I know that I will need the 345 cc peak/hold injectors for OBD-1. Any difference between the JDM and USDM VTEC injectors?
Old Nov 29, 2005 | 04:37 AM
NoVALude's Avatar
Default Re: Any Difference between JDM and USDM injectors (NoVALude)
Anyone?????
Old Nov 29, 2005 | 04:44 AM
Honda318dx's Avatar
Nope, not if they are the same OBD system..
Old Nov 29, 2005 | 04:58 AM
NoVALude's Avatar
Default Re: Any Difference between JDM and USDM injectors (Honda318dx)
I guess the more important part is the FPR anyways, not the injector.
Thanks!
Old Nov 29, 2005 | 05:24 AM
mgags7's Avatar
the fpr should be the same too....
Old Nov 29, 2005 | 10:11 AM
NoVALude's Avatar
Default Re: (mgags7)
I have some custom FPR that I got from Japan..
Old Nov 29, 2005 | 10:17 AM
Quick99Si's Avatar
Default Re: (NoVALude)
Is the FPR OE (JDM)? Wow that's a lot of acronyms
THe injectors look and feel identical, I've held both in my hands. I highly doubt they're any different internally heh
4th gen injectors are peak/hold and require a resistor box
5th gen injectors are saturated
So the market doesn't dictate base H22A injectors types, but rather the OBD'ness/generation.
Adi
Old Nov 29, 2005 | 11:07 AM
ludesrv's Avatar
H22s have some of the best injectors for flow. Alot of all motor B series guys buy our used ones for there motors.
They are the same flow for JDM and USDM. 300cc isn't bad for factory.
Old Nov 29, 2005 | 11:20 AM
NoVALude's Avatar
Default Re: (ludesrv)
I have a pic, but not sure how to set up here so you can see it....the pic I have was included in a Word document with instructions.
It is oil filled and looks real nice....
Old Nov 29, 2005 | 11:29 AM
Quick99Si's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ludesrv &raquo;</TD></TR><TR><TD CLASS="quote">H22s have some of the best injectors for flow. Alot of all motor B series guys buy our used ones for there motors.
They are the same flow for JDM and USDM. 300cc isn't bad for factory.</TD></TR></TABLE>
345cc for the OBD-I injectors but those would need a resistor box on 92+ Civics/Integras. The 97-01 H22A injectors were only rated at 270cc IIRC which isn't a huge jump over the OE 240cc on B-series DOHC VTEC engines.
Adi
Old Nov 29, 2005 | 11:39 AM
NoVALude's Avatar
Default Re: (Quick99Si)
Yeah I am swapping out my 92 H23 and throwing in a sleeved H22A4 block with type-s pistons (for now) and Crower cams..... already have the resistor box. I actually bought some injectors a while back, but they are only the replacement set for the H23 (non-VTEC).
Old Nov 29, 2005 | 11:47 AM
aaaabbbb's Avatar
Do not purchase anything from me. -HT Staff
wanna sell ur h23 block?
blaze the chemi
Jul 13, 2012 09:29 AM
EG2Driver
Nov 22, 2006 12:44 PM
CRXLST
Apr 1, 2005 08:09 PM
crj_lll
Jul 27, 2003 12:22 AM
