ITR Cam Shafts in b16 Head???
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CompressionFed »</TD></TR><TR><TD CLASS="quote">New bearings??? He shouldn't have any problems, all BVTEC cams are inter-changeable.</TD></TR></TABLE>
True all B-series do interchange...but where do the bearings go to install the CAMS? Or was the other person confused with replacing the bearings for the CRANK?
for some reason my ITR camshafts wouldn't turn after putting them in. My bearings may have worn out or something, my b16 head is a 1st gen so that may also be a factor.
edit: bushings, not bearings.
Modified by TheLastSpartan at 5:31 PM 11/28/2005
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blacksihatch »</TD></TR><TR><TD CLASS="quote">
There are no cam bearings on honda heads. Once the cam journals are gone, the head is junk...unless you want to pay big money to have someone weld, machine, and align the journals back to new.
</TD></TR></TABLE>There are no cam bearings on honda heads. Once the cam journals are gone, the head is junk...unless you want to pay big money to have someone weld, machine, and align the journals back to new.
