cel, wont flash codes, did search
Old Nov 28, 2005 | 09:00 AM
packman's Avatar
Default cel, wont flash codes, did search
Searched,
i'v gone as far as to cutting the grey plug off and warping the 2 wires together but the cel light will still not flash and codes,
iv tried different ecu's and still nothing,
P.s car ia a 92 hatch with sohc zc engine
thanks
Old Nov 28, 2005 | 11:47 AM
packman's Avatar
ttt
Old Nov 28, 2005 | 11:52 AM
tsdenny's Avatar
Default Re: cel, wont flash codes, did search (packman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by packman &raquo;</TD></TR><TR><TD CLASS="quote">Searched,
thanks</TD></TR></TABLE>
does the light come on when your driving? when you connect the two wires does the light stay on?
Dooley's Avatar
go to autozone.
they will check your CEL free of charge.
Old Nov 28, 2005 | 12:09 PM
postman's Avatar
Default Re: (kdm3nac3)
autozone only does that if you have obd2
Old Nov 28, 2005 | 01:16 PM
pornstarSR's Avatar
Default Re: (postman)
what ecu are you running... and why do you want to check it...
Old Nov 29, 2005 | 09:19 AM
packman's Avatar
Default Re: (pornstarSR)
Ecu is a p06 and i'v also tried a p28, cel stays on, flashes once when you start the car and stays on
the car is very hard to start all the time usually have to boost it
Old Nov 30, 2005 | 08:47 AM
packman's Avatar
Default Re: (packman)
ttt, i need this winter beater to run
please help
any ideas appreciated
Old Nov 30, 2005 | 08:50 AM
JDM-97CX's Avatar
It wont flash because there are probably no codes stored. And why would you try a different ecu? If there were codes stored they would be in YOUR ecu not some other one you had lying around.
Have you checked the battery? It is probably bad.
Old Nov 30, 2005 | 10:57 AM
packman's Avatar
Default Re: (JDM-97CX)
battery is no good,
the cel light stays on all the time, and car is a real pain in the *** to start, but once it warms up it runs fine has tons of power, but if it sits for more then an hour or so it takes aleast 10 to 20 min to start
Old Dec 1, 2005 | 10:06 PM
pornstarSR's Avatar
usually when the cel stays on the entire time that means theres a problem with the ecu itself... maybe even with a ground for the ecu...
Old Jan 17, 2006 | 12:15 PM
dnbruut's Avatar
did you find out wat the problem was? (hope you'll receive a reply email)
project91crxsi
Feb 20, 2012 07:24 AM
turbo sol
Apr 2, 2009 05:31 PM
stealth89hatch
Aug 15, 2005 04:48 PM
93si-hybrid
Jul 21, 2005 05:01 AM
92hybridAccord
Aug 20, 2003 12:28 PM
