vtec problem
my car isnt hitting vtec ... ? runs fine otherwise
i drive a 00 em1, so its a b16
i checked the oil, its a little low and blackish
would an oil change fix the problem ?
i searched, there was a lot of different possibilities
but i just want to know if just oil could be the problem
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by killaj12 »</TD></TR><TR><TD CLASS="quote">my car isnt hitting vtec ... ? runs fine otherwise
but i just want to know if just oil could be the problem</TD></TR></TABLE>
no.
no.
If the oil is a little low and blackish then that is where I would start as it seems an oil change might benefit you in other ways than trying to get your vtec to work as well.
It cant hurt is what Im trying to say
no, i cant hear it
its weird, it cracks in the upper gears, like 3rd
doesnt in 1st and 2nd
just noticed my coolant is really low too
under the minimum line
that wouldnt affect vtec engagement tho right ?
what about spark plugs/wires ? would that affect it ?
ugh, where should i go to check this out ?
honda dealership ? theres no shops around that knows anything about hondas except like 45min-1hour away
it wouldn't be the black oil that effects your vtec...but like someone said earlier...it doesn't hurt to change it. are you getting any check engine lights? is your engine at the correct temp. when you were doing these test for vtec? where exactly is your oil level...you aren't at like 1 quart right?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by killaj12 »</TD></TR><TR><TD CLASS="quote">no, i cant hear it
doesnt in 1st and 2nd</TD></TR></TABLE>
Its not going to pop as loud in 1st/2nd gear becuase of the tight gear ratio. If you hear the transition in 3rd/4th/5th gear then theres nothing wrong.
i understand it wont crack as loudly in 1/2
but you could hear the crack before, now you cant
it feels completely linear now
im gonna change the coolant and oil tomorrow morning, ill update then ig uess
